Trick Power Steering Pump.
Old Sep 3, 2002 | 03:24 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Trick Power Steering Pump.
I have to replace my power steering pump about every 2 years but this time I wanted something more trick, a better highperformance pump. I went to the local Canscar race shop and saw a small high performance pump nascar type pump that had a remote resovoir. It puts out 3 gallons per minute at a pressure of 1160 psi. It was super compact, light weight, safe to 9000 rpm and about $175 american plus mounting brackert plus remote resovoir. I bought the pump and the mounting bracket but the tank would not work for my application so I fabricated one .
I started with a air conditioning aluminum canister and a rad cap and filler neck. The large outlet is the in for the power steering pump and the 2 small #6 fittings are return lines for the power steering control valve and the hydraboost power brakes. This holds alot more fluid then a stock resovoir and hopefully cools it better with it's remote location.
I believe Monty runs a trick pump like this with the romote resovoir.
Anyway these are 2 pictures of my homemade tank. It bolt to the fender and the filler neck sticks out for filling. Most of the tank is hidden under the lip.
Old Sep 3, 2002 | 03:30 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Trick Power Steering Pump. (norvalwilhelm)
I'm disappointed Norval...I figured you'd make the whole pump! :jester
Pretty nice, especially sine my pump is failing :mad:
Old Sep 3, 2002 | 03:40 PM
Fevre's Avatar
Fevre
norval
Where are all the lumps and leaks like on my exhaust pipes? Stupid Tuffy muffler! :mad 'Quality exhaust work? Now that's a Tuffy!'
Looks very nice, thanks for the info.
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Very :cool: Norval. I'd love to see a pic of the pump too if you could post one ;) . How does the remote resovoir work since I know that the stock is sensitive to how much fluid you put into it? TIA :)
Old Sep 3, 2002 | 03:45 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Trick Power Steering Pump. (Fevre)
Cool! I have an aluminium KRC pump too and a Hydrobooster. I'm looking for a resevoir too that will fit somehow :)
This is my pump:
Marck
Old Sep 3, 2002 | 03:52 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Nice job, dude. Good looking welds
Old Sep 3, 2002 | 04:00 PM
norvalwilhelm
427V8. If I knew how to build a pump I would build one but that is beyond me :)
Fevre. I don't have any bumps or leaks on my exhuast system. I tig weld all the stainless joints and make a smooth leak free job of it. It just cost me about $1700 to do a good exhaust system but at least I have the tig welder for future use, like making a remote resovoir. I see lots of poor exhaust systems at cruise nights. I cut a splice stainless elbows together and don't try anymore for a one piece mandral bent system. I have access to a state of the art mandral bender but it has trouble with 90 degree 304 stainless bends. Mild steel is no problem but at 65 degrees the 3 inch stainless starts to wrinkle. I just buy elblows and cut and splice.
SmokedTires
As far as fluid level I don't know how to it affects it. I was just going to fill the tank so there was always a good supply to the pump.
I will post a picture of the pump and the mounting braket tomorrow.
Old Sep 3, 2002 | 04:03 PM
norvalwilhelm
Default Re: Trick Power Steering Pump. (Twinnie)
Twinnie. That is the pump. It is light weight, puts out 1160 psi and the mounting bracket is about $45.00 CDN. It comes in blue, red and something else and bolts directly to the block or heads depending on which one you order.
Old Sep 3, 2002 | 04:09 PM
Twin_Turbo's Avatar
Twin_Turbo
Can't use the head mount, must use block mount because of turbochargers. I still need the bracket, moroso sells the bracket as does sweet. Haven't seen a KRC bracket. These pumps can be had in cast iron and the lightweight alu version.
I needed this pump because I couldn't use the stock one, turbo in the way (couldn't fill it)
I like the fact that yours has 2 returns, one for PS valve & 1 for HB
Here's the KRC kit, bracket & tank included (I don't like the looks of that tank though)
Marck
Old Sep 3, 2002 | 04:12 PM
Monty's Avatar
Monty
Good looking TIG welds Norval, I wish I was that good at aluminum. I'm pretty good with stainless, but haven't had enough practice with aluminum yet. I bought my pump, block mount bracket, and reservoir from CV Products.
I don't feel so bad now about over-engineering everything and being a sucker for trick looking NASCAR-type components...looks like there are many others with the same disease :).
[Modified by Monty, 2:14 PM 9/3/2002]
Old Sep 3, 2002 | 04:14 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Trick Power Steering Pump. (Monty)
I'm guilty :)
Old Sep 3, 2002 | 04:35 PM
Monty's Avatar
Monty
Out of curiosity, are you using 5356 or 4043 filler rod? I assume your reservior is 6061. Looks darned good.
norvalwilhelm
Thank you Monty for the compliments. Comming from you they mean alot.
Old Sep 3, 2002 | 04:41 PM
norvalwilhelm
Monty. 4043 in the preferred rod but it can not be anodized. The welds turn black. 5356 is second choice and it accepts anodizing , so depending on your finish , decides which rod to use.
As for 6061 I don't know. I started with a airconditioning tank that was welded so I assumed it was ok to weld. I machined the weld off one end and the tank came apart. Since the factory could weld it I assumed it would be ok for me.
Old Sep 3, 2002 | 04:45 PM
Monty's Avatar
Monty
As I mentioned, I still have alot to learn when it comes to TIG welding aluminum, I did not know that about anodizing. I have always used 4043 myslef, but someone recently told me that 5356 produced a stronger weold, while 4043 had better corrosion resistance.
Old Sep 3, 2002 | 04:58 PM
Twin_Turbo's Avatar
Twin_Turbo
5356 filler rod is used when welding 6061 to 3003.
1100 filler is fine for 3003
6061 or 5052 use the 4043 filler rods.
Old Sep 3, 2002 | 05:11 PM
NHvette's Avatar
NHvette
Very very nice, Norval. I can't wait to be thinking of pretty parts like that.
Way to go!!
I sure wish I still got up to Waterloo like I used to - love to check your
vette in person. Dinner on the top of the CN - weekends at the falls.
Alas - those days are over for now. :(
:seeya
Old Sep 3, 2002 | 06:10 PM
Edzred72's Avatar
Edzred72
Norval.....Wish I could weld like that. Beautiful!!!!!!
Eddie
To Trick Power Steering Pump.
