Post#2 Motor mounts, and other stuff
Old Sep 3, 2002 | 04:10 PM
97Z's Avatar
97Z
Default Post#2 Motor mounts, and other stuff
I am in the process of ordering parts for the LT1 swap in to a 78 Pacecar. I am using the motor out of a 96 corvette with a t-56, 6-Speed. I am wondering if the motor mounts will line up or not, if the stock (1978) ac components will work with the newer compressor, and can I use an out of tank fuel pump(like a holley, or weiand), and still have the correct fuel pressure and volume. and how will the shifter line up in the interior cabin? I know the Original 4-speed uses external shifer rods, whereas the T-56 uses internal. How could I get around this? I know its alot of questions but I want to do this right(This is the same car I rode home from the hospital as a new born, and the car my parents took on a honey moon.)
:cheers:
Old Sep 3, 2002 | 08:46 PM
97Z's Avatar
97Z
Default Re: Post#2 Motor mounts, and other stuff (97Z)
TTT, I would also like to know if anyone else knows where I can have custom A/C lines made. Mike :cheers:
Old Sep 4, 2002 | 06:02 PM
97Z's Avatar
97Z
TTT, some help please? :cheers:
Old Sep 4, 2002 | 06:03 PM
PatsLs1vette's Avatar
PatsLs1vette
check with vettedan ,and ls-1 , they both have that motor in theres and know what had to be done.oops read it wrong you want a lt-1 in yours not the ls-1.the lt-1 motor mounts should be in the same spot as a standard 350.
and yes you can use an inline pump for the fuel injection holley aeroquip and a few others make a pump for mpfi.
[Modified by pats406nitrovette, 5:05 PM 9/4/2002]
[Modified by pats406nitrovette, 5:06 PM 9/4/2002]
[Modified by pats406nitrovette, 5:57 PM 9/4/2002]
Old Sep 4, 2002 | 06:40 PM
97Z's Avatar
97Z
Default Re: Post#2 Motor mounts, and other stuff (pats406nitrovette)
thanks man. :cheers:
To Post#2 Motor mounts, and other stuff
