Manual door locks reversed?
Old Mar 17, 2016 | 08:11 PM
80L48's Avatar
80L48
Default Manual door locks reversed?
I just bought a 1980 Corvette with Electric windows but manual locks. The Driver Lock and Passenger lock work in the opposite direction. To lock the Driver's door while inside, you must "PULL" the lock up and away from where it goes into the armrest. On the Passenger side, you have to "PUSH" it in to Lock it. This doesn't seem correct. I have had the trim panel off and the linkages seem to be connected properly. Is it supposed to behave like this? If not any thoughts on how this could happen? I think they should both lock when you PUSH them in.
Old Mar 17, 2016 | 08:24 PM
toobroketoretire's Avatar
toobroketoretire
A previous owner put something together backwards.................
Old Mar 17, 2016 | 08:51 PM
80L48's Avatar
80L48
Yes, suspected that. Which way are they supposed to work, and does anyone know how that might be done? (while the linkages still appear to be correct?
Old Mar 17, 2016 | 09:01 PM
righthanddrive's Avatar
righthanddrive
Both should push into the arm rest to lock. Someone put it back together wrong. The AIM has diagrams showing the proper linkage attachments
Old Mar 17, 2016 | 09:05 PM
80L48's Avatar
80L48
AIM.. Is that a manual of some sort? I just got the GM Service manual for it, but the pics are not good enough.
Old Mar 17, 2016 | 09:26 PM
righthanddrive
Assembly Instruction Manual. They are available through several vendors. One of the members may even be able to copy a page to you.
The AIM is a very useful tool to have for working on these cars.
Old Mar 20, 2016 | 01:46 PM
80L48's Avatar
80L48
Solved and fixed! Someone had reversed the lower linkage connections. All good now! On the the next improvement to be made!
To Manual door locks reversed?
