Help, my tach went crazy
Old Mar 18, 2016 | 07:26 PM
rmgny44's Avatar
rmgny44
Default Help, my tach went crazy
Out driving today cruising along at 60 mph and my tach went crazy. It was bouncing around all over the dial. At idle it doesn't move.
Would appreciate any advise.
Old Mar 18, 2016 | 07:39 PM
BKbroiler's Avatar
BKbroiler
First we need to know if it is cable driven or electric. If electric, probably a bad tach filter.
Old Mar 18, 2016 | 07:51 PM
rmgny44's Avatar
rmgny44
The car is a '72 completely stock so I believe it's mechanical.
Old Mar 18, 2016 | 07:55 PM
redvetracr's Avatar
redvetracr
yea, pull the side gear out of the distributor if it`s bad replace BOTH gear and mainshaft
Old Mar 18, 2016 | 09:42 PM
rmgny44's Avatar
rmgny44
Very Strange! Cars been sitting in the garage for a few hours. Went out, started it up and now the tach works fine.
Old Mar 18, 2016 | 10:45 PM
babbah's Avatar
babbah
I have been there as well with the tach. I guess I should not complain as it has never been touched in 49 years & still working!
Old Mar 18, 2016 | 11:47 PM
rmgny44's Avatar
rmgny44
So from what you're telling me mine should work for at least another 5 years!
Old Mar 19, 2016 | 01:13 AM
babbah's Avatar
babbah
It should! LOL! All my gauges are original and still working in my 1967 (working since my high school days! Not to bad for almost 50 years)
In addition, the clock is original as well and is still ticking. Go figure!
(love that tic tic tic and click of the mechanical rewind sound when parked)
Old Mar 19, 2016 | 02:07 PM
454Luvr's Avatar
454Luvr
My '72 did the same thing (40 years ago). I don't know how a mechanical drive can become intermittent, but that's what it was.
Old Mar 20, 2016 | 03:52 PM
rmgny44's Avatar
rmgny44
Okay, something is wrong! Out for a drive today and after running fine for a while the tach stopped working and shortly after that the car lost power. I managed to limp home but it was like it was not running on all cylinders. Shut it down and started it again after a few minutes and the tach works and the engine sounds fine again!
Old Mar 20, 2016 | 04:18 PM
454Luvr's Avatar
454Luvr
Is there any possibility someone has replaced the mechanical tach with electronic?
Old Mar 20, 2016 | 05:50 PM
rmgny44's Avatar
rmgny44
It's mechanical!
Old Mar 20, 2016 | 07:35 PM
454Luvr's Avatar
454Luvr
It's mechanical!
In that case, it's the distributor. I don't know how a defective tach gear drive can cause misfires, but that's clearly what's happening. The gears must be binding and causing a problem with the timing somehow.
Old Mar 20, 2016 | 07:55 PM
mikem350's Avatar
mikem350
I doubt this very much. Gear binding cannot cause the dizzy shaft to stop turning, it would cause the tach CABLE to stop. I believe the engine is mis-firing causing the tach to read off. The tach needle is driven by a magnetic coupler that can slip and cause the needle to bounce and read wonky.
Find out cause of misfire!
Old Mar 20, 2016 | 08:49 PM
babbah's Avatar
babbah
Old Mar 20, 2016 | 09:16 PM
454Luvr's Avatar
454Luvr
I wasn't suggesting that the distributor is stopping. If end play in the shaft is excessive, gear binding might cause timing to change.
Why would a misfire cause a mechanical tach to read off? The coupler isn't electromagnetic, it doesn't require voltage or horsepower to function. I agree it can fail, but I don't see how that could be related to misfires. Maybe the car actually has two different and unrelated problems, but it's a stretch to believe they could happen on and off at exactly the same time, strictly by coincidence.
Old Mar 21, 2016 | 07:53 AM
rmgny44's Avatar
rmgny44
Car is going into the shop tomorrow morning. I'll let you know what we find!
To Help, my tach went crazy
Old Mar 21, 2016 | 12:47 PM
mikem350's Avatar
mikem350
I stated that the tach NEEDLE is coupled by magnetism. This is a known failure mechanism for intermittent/bouncy tach needles. My car actually suffers from this, but not as bad as the OP.
Go on the Willcox site for more info.
Old Mar 21, 2016 | 01:40 PM
454Luvr's Avatar
454Luvr
Yes, I got it the first time. Same question though: Why would a misfire cause the tach to read off?
Old Mar 21, 2016 | 01:49 PM
mikem350's Avatar
mikem350
I feel the OP has an intermittent tach...AND possibly engine not running right. The tack came back to life after sitting overnite.
