Mufflers Whats Inside
Later on had them behind the 540 in it's first version with 3" pipes. Uncapping it was literally a 50 RWHP difference!
JIM
Just follow procedures and the metal will tell you if you did it right.
twin flow meters
back purging
trailing cup
gas lens
proper rod
short weld length
clean
clean
and clean
All of the above plus lots of practice.
To properly weld thin stainless requires at least a back purge.
Thanks for the first reply that actually addresses the purpose of this thread.
Modifying C5 titanium mufflers to fit a C3 and building the accompanying titanium exhaust system.
I do like them, and recently bought a set of Delta 40s for my dad's mild 358" SBC, they sound great on just about anything, but I wouldn't run them on anything that's making over 350-400hp....They just don't flow well...
A buddy of mine has a 78' Malibu with a mild/oldschool 468", 3" exhaust with x pipe to 2 chamber Flowmasters (the black/square ones like the original style from the early 90s), 3" tail pipes over the axles. He has QTP cut outs on it as well right before the muffs. On the chassis dyno, he gains 27 rwhp with the cut outs open... A-B-A test style, and this is only on a 350 rwhp car....
Now the Flowmaster shootout mufflers, that's another story...
On most cruiser type cars, 2 chamber Flows are great...
Flowmaster designs all of our mufflers for performance, but it is important to select the right muffler and appropriate size for your application. Running a muffler which is improperly sized, either too small or too large internally and externally, can cost you power. With a properly sized exhaust system and mufflers, Flowmaster mufflers will increase exhaust gas scavenging and free up available power. Our muffler designs have been improved upon over the years in search of more power, and we will continue to improve them into the future.
If anyone ever has a question about how a particular Flowmaster muffler or exhaust product will affect their system's performance, give our Tech Line a call at 707-544-4761 and we will make sure that we get you the correct components for the sound and performance needs of your vehicle.
I've owned no less then 20 pairs of Flowmasters on various cars since they were introduced in the early 90s...
It wasn't until I really started getting into chasing ET/MPH that I discovered the design constraints...Ofcourse chasis dynos help with testing as well.
Flowmasters were the gold standard for performance mufflers in the 90s and still the gold standard for sound today...they satisfy looks, performance and sound for about 80% of car enthusiasts....the rest of us that are chasing every last HP know that a "straight through" design muffler makes the most power, this is already assuming the exhaust system is sized correctly..
Like I mentioned, I still like them, and I still buy them...I just don't put them on my "fast" cars..
Flowmaster works very closely with a number of race teams and professional car builders so that we can receive unbiased feedback about the quality and performance of our products. Aside from our full line of street mufflers, we also offer an entire line of race mufflers which have been designed for the absolute best performance in high horsepower applications.
Ultimately, your muffler choice is entirely up to you and we truly appreciate your support over the years. If you ever have a question about exhaust system performance in a race application, don’t hesitate to contact our Tech Line for additional information.
That's my take on physics, and my exhaust system build philosophy. I've run different size exhausts in my cars over the years, and in most cases I weld a pressure tap into the pipe as close to the headers as I can. This gives me actual readings of the backpressure of the systems, and an indication of the flow efficiency of the system. I use a low range Magnehelic gauge for measuring the exhaust (and intake pressure drops). This gauge has a range of 0-40" H2O, or about 1 1/2 psi max.
Here's a picture showing the three internal tubes/chambers. The right side chamber is essentially a surge tank to help soften some of the pressure/sound vibrations, while the center and left side tubes are parallel paths for the exhaust gas flow. The reasons for the two tubes are partially to minimize flow restriction, but mainly to increase the surface area of the tubes to the fiberglass dampening material surrounding the tubes. All three tubes have hundreds of small drilled holes and slots to allow the pressure/noise vibrations to be attenuated by the movement into and out of the surrounding volume.
Nothing new invented here, this muffler is just a combination of a chambered muffler and two glasspacks in parallel. I like having expansion/surge/reflection volumes in a muffler, but unless you have the noise frequency content measuring equipment (and I don't) to measure what frequencies you need to deal with, it's too much of a crapshoot for amateurs like me to not include dampening material in the design. I've got an inexpensive dB sound meter and measured the idle and 2000 RPM fast idle exhaust noise, and the readings are thankfully very close (Still waiting for a spring track day to see what the system sounds like at WOT). There is a subtle difference in sound "personality" between the two sides, but unless someone sticks their head right down between the bumpers I don't believe anyone will notice the difference in sound or build material between the two mufflers.
I built the aluminum muffler (3 1/2" I/O, and aluminum undercar piping) for my '84 a while back (before the muffler on the '69). I welded up this setup strictly for track day use (it's about 40# lighter than the stock dual muffler setup), but it's so reasonably quiet that I don't see a big need to take it off after each track day. The nice thing about a turbo is that it converts the pulsed exhaust exiting the exhaust port into more of a steady-state flow, easing the requirements of the system, particularly the muffler(s).
This is a straight through glasspack design, but like the muffler on the '69 there's an additional surge volume in the right half to allow additional tube surface area (with a crapload of holes) for noise vibrations to interact with the surrounding fiberglass packing.
FWIW, here's the gauge package I used to check out the system backpressure (at the turbine outlet), along with the turbine inlet pressure and the pressures at the compressor inlet and outlet.
Last edited by 69427; Apr 14, 2016 at 01:34 PM. Reason: Partially finished adding additional content.
Thanks for posting the pictures of your aluminum muffler.
I have been hoping you would.
Did you pack the whole case with fiberglass or just the ends?
Did you consider using the stainless wool instead?
I have enough 2 ½ titanium tube and mandrel bends to go from the collectors to exhaust tips including an x pipe.
The Z06 titanium mufflers are 15x11x5 oval and about 9lbs with the big stainless hanger still on it.
They need the inlet and outlet reconfigured to offset on both ends.
I have some 2 ½ perforated tube to accomplish that.
I have been thinking that 3 tubes similar to yours might be the way to go and am considering U shaped deflectors at each end like a turbo muffler.
I am not sure if I should remove some or all of the baffles or not and if the center tube should be perforated.
Keeping it quiet is more important to me than power as it is my daily driver.
What I want is no drone and similar loudness to a stock Z06.
At the bottom of this page in
Similar Threads
Inside a stock muffler
C5 Tech
There are pictures of the inside of a titanium muffler.
I hope to lose 40lbs to 50lbs and go from the mid 2900lbs to high 2800lbs.
Any thoughts or ideas you might have would be greatly appreciated.
Did you pack the whole case with fiberglass or just the ends? I packed the material on all sides of the internal "perforated" tubing.
Did you consider using the stainless wool instead? Yeah, but I haven't run into a local source for the fine mesh stuff, so I just used what worked well for me on the '84. I did try the bigger mesh stuff I found somewhere a few years ago, but wasn't happy with it.
I have enough 2 ½ titanium tube and mandrel bends to go from the collectors to exhaust tips including an x pipe. Color me envious.
Post some section weights of the system when you can.The Z06 titanium mufflers are 15x11x5 oval and about 9lbs with the big stainless hanger still on it. That's pretty decent. There's a chart of C6Z06 parts weights in the C6 section, and I got the impression they were a bit heavier than that.
I am not sure if I should remove some or all of the baffles or not and if the center tube should be perforated. Whichever direction you go, please post some photos of your progress.
What I want is no drone and similar loudness to a stock Z06. The best thing I did to reduce the drone dramatically was to put an H pipe immediately behind the header collectors.
Similar Threads
C5 Tech
