special electrical connectors
Old Mar 26, 2016 | 12:24 AM
Kacyc3's Avatar
Kacyc3
Default special electrical connectors
Where do you guys get yours? i am trying to get my new gauges installed and am trying to find a 12 pin connector to make them easy to disconnect. i have some connectors from radio shack but they dont appear to be what I need.
Old Mar 26, 2016 | 01:35 AM
454Luvr's Avatar
454Luvr
I use Molex connectors for most things. There are a number of sizes and many pin configurations available. If you have a Fry's nearby, it's good to be able to look at them first. Otherwise, you can order online from companies like Mouser Electronics and DigiKey.
Old Mar 26, 2016 | 09:44 AM
Kacyc3's Avatar
Kacyc3
I have some that look similar I picked up at radioshack but they don't lock together.
Old Mar 26, 2016 | 10:01 AM
Richard454's Avatar
Richard454
Go to a junkyard... you can find much better quality than the radio shack stuff. BMW uses a really nice slide lock type connector on the interior. Real copper wire (not copper coated aluminum) that's easy to solder.
I'm using this 17pin for the center gauge and console-
Albeit a totally custom dash-I can unplug the speedo and tach w/ one click and remove the tach from the dash pod-
Old Mar 26, 2016 | 10:22 AM
Vette-kid's Avatar
Vette-kid
Richard, you have got to be the most resourceful and talented individual out there! When is that car of yours going to be at a show so I can come check it out!?
Old Mar 26, 2016 | 10:52 AM
3X2's Avatar
3X2
I use Mouser.
[url]http://www.mouser.com/
Old Mar 26, 2016 | 11:04 AM
Solid LT1's Avatar
Solid LT1
Ballenger motor sports has automotive type connectors. You can look at the current Delphi 150/280 series of connectors on EBay, Deutsch connectors are another type. Cannon plugs are military standard and cheaper versions are avalible in plastic. Digi Key, Newark Electronics, Waytek Wire are great sources too.....look up muti-connector at major electronics supply houses.
Here is a 16 pin Delphi set for under $15 (never hurts to give yourself a few extra spots for future additions when custom wiring)
Link: http://www.ebay.com/itm/DELPHI-GT-28...hTknKd&vxp=mtr
Old Mar 26, 2016 | 11:18 AM
Kacyc3's Avatar
Kacyc3
any specific car to be looking for?
Old Mar 26, 2016 | 12:07 PM
Richard454's Avatar
Richard454
THANKS-Sean!! And Congratulations on the Baby!!!
Old proverb-"Necessity is the mother of invention!!!"
"When the need for something becomes imperative, you are forced to find ways of getting or achieving it."
I hope to be on the Hotrod Power Tour this year!!!
I just happen to a BMW 7 series late 90's as a parts car in my garage..
FWIW- these cars were $100k NEW ( have the window sticker) and have really nice wire & connectors before CAN bus..as the wires were designed for 12 volts and they used some really good stuff.
This one came from the heated/power rear seats-oh power head rest too!!! Has a slide lock and nice gauge wire-
Here's some really nice battery cable- found some uses for it too!!!
Old Mar 26, 2016 | 12:24 PM
454Luvr's Avatar
454Luvr
One of my other interests is the design of high-end audio amplifiers (vacuum tube). Radio Shack used to carry good quality parts like potentiometers, capacitors, resistors, etc. Now they source virtually everything from China, and I've stopped buying from them. Molex-style connectors that don't lock together sounds about right.
Back on topic, Molex also makes a series of smaller locking connectors like the one below. None of this style are sealed, but they're very inexpensive (less than $0.50 without pins). In an automotive environment, I keep moisture out by filling open connectors with white or clear grease before assembly.
http://www.digikey.com/product-detai...056-ND/1649619
Old Mar 26, 2016 | 01:02 PM
GUSTO14's Avatar
GUSTO14
Kwik Wire out of Fond du Lac , WI is very big in the hotrod market. They had a large trailer and tons of stuff in Myrtle Beach last weekend for the Run to the Sun Car Show.
I could'a spent a couple of hours looking through all of the stuff they had to help clean up any custom wiring situation you might encounter. Everything from multi-pin weatherpack terminals to rubber grommets and everything in between. It's the kind of stuff that until you put your eyes on it, you don't realize how much you really need this or that item.
Good luck... GUSTO
12 Position Amp Connector Kit - $6.50
http://kwikwire.com/connectors-termi...connector-kit/
Old Mar 26, 2016 | 02:40 PM
Kacyc3's Avatar
Kacyc3
Now thats cheating I found some from rwd (i think) acura and some relays from a Mazda that had descent gauge wire connected.
Old Mar 26, 2016 | 08:37 PM
454Luvr's Avatar
454Luvr
That's a nice looking connector! Were the wires long enough so you didn't have to pigtail all 14 of them? That would be a pain.
Old Mar 27, 2016 | 10:31 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
Del-City is another electrical supplier...no minimum purchase required...reasonable shipping charges and good customer service....
Old Mar 27, 2016 | 08:00 PM
babbah's Avatar
babbah
Originally Posted by 3X2
I use Mouser.
Same here.
To special electrical connectors
