Tach not working
Old Mar 26, 2016 | 02:01 PM
psycho dad's Avatar
psycho dad
Default Tach not working
Hey Guys,
My tach stopped working on my 76 auto. I removed the starter recently, when I re-installed tach was broke. I don't know if its related.
The tach is frozen at 5300, nothing happens when I unplug from distributor.
Is there a good way to check to see if it's the tach board or something else?
Thanks!
- Jay
Old Mar 27, 2016 | 10:18 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I would pull the connector off the back of the tach, it's kind of hard to reach but very do-able...
Then test the tach wires at the connector for power (C) and ground (D). If you have power and ground, then test continuity on the brown signal wire from the connector to the filter connector. If you have continuity from A to B then bypass the filter and plug the brown wire straight into the coil... If the issue stays, replace the tach board, if the issue goes away, replace the filter.
If you do need to remove the tach for repair, here is the easiest way to remove the left hand lower dash pad. It sounds hard but it's not...
1968-1977 Corvette Left Hand Dash Pad Removal
If you wish to install a new tach board..
Here is how you do it:
And if you need a new board that is USA made and works like the original.. we'll I've got them too https://willcoxcorvette.com/corvette...75-77-usa-made
There is a ton of tach info on my tech site and it can be found at this link: http://repairs.willcoxcorvette.com/?yt=1976&s=tach
-Willcox
Old Mar 27, 2016 | 11:20 AM
psycho dad's Avatar
psycho dad
thanks for the info! Looks like I'll be placing an order soon.
Old Mar 28, 2016 | 09:23 AM
croaker's Avatar
croaker
Could the Tach filter be bad? Check with ohm meter?
Old Mar 28, 2016 | 06:17 PM
psycho dad's Avatar
psycho dad
best I can tell I don't even have a filter. the wire plugs into distributor
and goes into the firewall. It's not under the dash is it?
Old Mar 28, 2016 | 08:45 PM
0Willcox Corvette
Former Vendor
Nope.. it's round bolted to the intake and it's common for someone to remove it...
To Tach not working
