Rear rotor runout - shims
Old Apr 29, 2016 | 10:33 PM
BlackC3vette's Avatar
BlackC3vette
Originally Posted by jim-81
Yes, I did them.
Nice, not many would try it. If you had to do it again, would you do them or send them out?
Old Apr 29, 2016 | 11:36 PM
Kid Vette's Avatar
Kid Vette
They are made from .025" stock with a taper ground on them. The ones to correct .003" runout have .0015" taper and the ones to correct .006" runout have .003" taper.
Old May 6, 2016 | 01:05 AM
dariopop's Avatar
dariopop
Jim-81
A few years ago I installed the VBP Performance Plus Suspension package with new rear ( rebuilt )
Spindles and new disc brake rotors. I tried for weeks to cure my run out. Got it within .003 Never got rid of it and the result was every month or so I would have to bleed my system because of low pedal. As the Rotor rotates it sucks in air. I went thru this for a year or so and I got tired of doing it. Someone on the site suggested
Changing to. " O " rings and get rid of my old lip seals in the brake calipers.
Its been two years now that I changed them ,and I have yet to bleed them after the change. Plus I have a much better brake pedal with the O rings.
Good luck with yours.
Dario
