1979 corvette
Old Mar 29, 2016 | 12:12 PM
Rlanza's Avatar
Rlanza
Default 1979 corvette
I'm trying to order fan belts date coded for my car the belt company wants to know if they are first design or 2nd design my car date is March 17 1979 does anybody know how you can tell / Thanks
Old Mar 29, 2016 | 01:23 PM
Bloodzone's Avatar
Bloodzone
Never heard of a "first" or "2nd" design designation. They may be referring to the early or late 79s. Early 79s have 3 door storage behind seats. Late has 2.
Old Mar 29, 2016 | 01:33 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Ask the belt company how they define early and late.
Old Mar 30, 2016 | 03:55 PM
Rlanza's Avatar
Rlanza
they told me they don't know how
Old Mar 30, 2016 | 06:43 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Good luck with this!!
Years ago I went round and round with both DocRebuild and Zip trying to get "correct" belts.
There are different sizes for 79s based on 4 speed, auto, L82 or L48, AC and probably something else.
One of the problems I had was the alt belt. Original is 3/8" wide. The supplied dated/numbered repro belts were both 7/16" wide but the "correct" length.
Seems the correct length in 7/16" is too short than the 3/8" belt cause it rides higher in the grooves. The specific AC belt I needed(I read the no./date/size right off the original) didn't exist! I think I settled for longer.
Power steering shouldn't be a problem. It's either 3/8" X 36 or 7/16" X 36 1/2". Probably be limited to the 7/16".
Old Apr 14, 2016 | 06:05 PM
accorvette78's Avatar
accorvette78
1st Gear
Default 1979 Fan Belts
Here is a good resource I have found for the engine fan belts:
http://www.mamotorworks.com/Corvette...n&Y=1979&G=&C=
You can also search for other years by changing the drop-down up by the search bar to sort out the relevant years.
They have all the belts listed that were available for the 1979 with GM#'s. All you have to do is select the correct quarter your car was produced in.
Hope this helps.
To 1979 corvette
