tach cable is sticky
Old Apr 4, 2016 | 06:40 PM
CiCiC3's Avatar
CiCiC3
Default tach cable is sticky
I'm going to replace my cable with a new one shortly but I disconnected it from the distributer and ran a little tape around the opening to keep dirt out. There should not be a vacuum problem or any other kind of problem with doing that?
Old Apr 4, 2016 | 08:19 PM
drwet's Avatar
drwet
Nope. Not a problem as long as you can live without the tach. While you're working on it, make sure you disassemble the distributor drive gear and lubricate it.
Old Apr 4, 2016 | 09:51 PM
CiCiC3's Avatar
CiCiC3
Sure I'll put that on the list also. Thanks, gotta get this out in the spring weather!
Old Apr 4, 2016 | 09:54 PM
drwet's Avatar
drwet
You have Spring weather? No fair. Its snowing here.
To tach cable is sticky
