I have a 1973 Coupe, with the 454, TH400 automatic trans and 3:36 gears in the rear end. I'm thinking about swapping the rear end gears to the optional 3:08's to drop a couple hundred RPM's at cruising speed on the highway. Does anyone have the optional 3:08 rear end ratio? What RPM are you seeing at 70 mph? Does the trans want to kick down on an incline? Does the motor bog down because the RPM's are to low? How does the lower RPM's effect cruising through a winding road? What are the positives and the negatives?
A 27" diameter tire with a 3.08 and 70 mph equals 2,683 RPM versus 2,927 rpm currently with the 3.36. The 3.08 would have been an optional rear on a 1973. If your engine is stock there should be no shifting or bogging issues.
Couple things I will add. The more torque, the more a 3:08 would be fine (read BB here). A light car (read vette) will also have less issues with the 3:08.
I have had torquey V8 cars with 3:08/TH400 and liked the gear for a cruiser.
As far as bogging, no problem.
Another thing to consider: a properly matched torque converter can really make a huge performance change with a tall 3:08
I had a 3:08 gear in my car and it was okay with my stock 74. When I decided to put some horse-power in the car I immediately switched the rear end to a 3:73 and installed a 700-R4 and and it really made a World of difference. Wish I had done it earlier.
2016 C2 of Year
2015 C3 of Year Finalist
My 68 427/390 with Turbo 400 and 3:08 rear turns around 2600 RPM's at 70 mph. It's a stump puller off the line and there is no unnecessary downshifting going up inclines or driving on back roads. Big blocks make so much low end torque and the Turbo 400 1st gear is a perfect compliment to pulling well out of the hole. Not a huge difference though, between the 3:36 and 3:08. A bit better on the highway if you like to travel in it.
My plan is to do a frame off restoration next year. Beside everything else, I plan to go through the motor and increase the compression ratio to 9.5:1, do a 30 over bore, install a good bottom end to mid range camshaft, balance, replace the heads, install a good intake, headers, new ignition and a new carb. I plan to cruise down the highway, through the foothills, the Sierras and Lake Tahoe.
I have a set of 3.08 gears; they will drop the rpm 10% from what you're seeing now.
As far as performance, the 3.08 can work well if one uses a higher stall torque converter such as a tight 10" converter. With my former '78 Vette running a 406 SBC with a Quadrajet carb on an Edelbrock Performer RPM (pn 7104) manifold and a TH350 trans, I could turn easy 11 sec quarters with short times of ~1.75 sec. The advantage of the 3.08 is that it would hook better without blowing away the tires than a lower rear end such as a 3.70.
Mileage wise, I could get about 17 mpg on road trips due to the good hook up of the tight Continental converter.
Actually, buying a new set of gears and having them swapped professionally can be accomplished for a reasonable price with no modifications. Since I'll be replacing everything in the rear differential anyway the gear swap will only be the cost of the new gears. The stock torque converter should work fine for my application. I'm still putting some miles on the car so I can see what it needs to perform and handle the way I want it to before I start the restoration. After all it is a Corvette and should perform and handle like the sports car it was designed to be.
7004r and 355s with 255/60/15s = 2000ish rpms at 70mph. Do you drive the car hard anytime or just cruise around?
My friend, I think you got everyone else's opinion what they would do.
But more important as asked what do you want from the car?
I have a 427/390 M-20 3:08 stock set up.
I can lug in 4th gear through a 15 mph school zone, then accelerate
out of it and be at 50 mph in a blink.
At 50 I can give the edelbrock 1401 a lil juice and be well up into 3 figures.
I too am under 3 grand at 70mph.
I do cruise nights, weekend drives with the 1st Sgt, and some spirited
twisty's along the river near my home.
I can drive all day at any speed in 4th with the 3:08 set up.
I also have AC, P/S, P/B, Tele wheel, so who ever ordered it originally meant to drive it.
If I was looking for a muscle car to do the old high school burn outs
I'd get a chevelle with line locks, turbo hydromatic 350.
This is America's one and only original sports car.
To me it's Americas Austin Healey on steroids.
Marshal
I also have AC, P/S, P/B, Tele wheel and power windows. The questions I have about swapping the TH400 for an overdrive automatic is:
1. Will it bolt right up to my 1973 454?
2. Will it handle the additional torque and horsepower of a mildly modified 454?
3. What about the transmission mounts, aren't they different?
4. Will I need to modify the frame mounting?
5. What about the tail shaft length? will I need to replace the drive shaft?
A 700r4 will bolt to your engine and you can get one that can hold up to 800HP if you need it , but you will need X-member modification for mount to match. Driveshaft will need to be shortened, $90 at any driveshaft shop. move the PBrake pulley 1 inch to left . And convert Shifter Detent to allow for 4 forward positions ... I run 525HP/498 FTLBs Torque with a 700r4, and 3.73 gears. I can cruise all day at 80 MPH turning only 2550RPM ....or embarrass the crap out of others from a stoplight
Thanks for all the great comments. I think I have more planning to do.
I think you already have a nearly ideal gearset for today's highway speeds. My '72 454 had 3.73s. I made plenty of long trips, but the limit back then was 55 mph. Purely from a gearing standpoint, I agree with the concept of swapping to a 700R4. However, the TH400 is really a brute of a transmission. I abused mine for years, more than 80K miles, and it only finally started slipping because the filter clogged up. For that reason alone, I'd think twice about getting rid of one.
I had the same experience with my 74 big block 427 with a 4 speed. If your 454 is running correctly, you shouldn't have any bogging or hesitation. You either need carb work or possibly the hormonic balancer shifted and your timing is incorrect due to the timing mark being off.
