Differential fluid type 1975
Old Apr 5, 2016 | 09:09 PM
Dom_vette75's Avatar
Dom_vette75
Cruising
Default Differential fluid type 1975
i am unable to get to my manual due to storage and this is my first diff fluid change. what weight should i use? i already have my GM additive, should i stick with GM gear oil? or is any other brand non-snyth oil okay?
Old Apr 6, 2016 | 12:03 AM
Franks73's Avatar
Franks73
Default Rear fluid
Hello. There has been much discussion on this topic. Many feel modern synthetic fluid is fine. Others say stick with the GM fluid. My 73 sat for MANY years. When I finally was able to drive it, had a clunking noise. Suctioned out the new fluid, with a turkey baster and tube, took a while, but worked. Put in GM fluid, and two 4 oz bottles of additive. Drove in figure 8's, or opposite circles, to exercise it, noise gone! Plenty to read on the topic on this forum, which is a great forum! Good Luck!
Old Apr 6, 2016 | 09:01 AM
bashcraft's Avatar
bashcraft
You can buy fluid with the additive already in it. I use Pennzoil, but there are many others.
Old Apr 6, 2016 | 10:37 AM
fishslayer143's Avatar
fishslayer143
Synthetics are far superior .. Put the Friction modifier in before the gear oil.
Old Apr 6, 2016 | 11:17 AM
Peterbuilt's Avatar
Peterbuilt
What weight should i use?
SAE 80W or SAE 80W-90 GL-5.
To get the nut off use a 8 point 5/8 socket.
https://www.gmheritagecenter.com/gm-...tion-kits.html
Old Apr 6, 2016 | 06:47 PM
jb78L-82's Avatar
jb78L-82
I have used Mobil 1 75W-90 synthetic for 26 years now with no friction modifier and the diff is perfect...go synthetic...friction modifier or not
To Differential fluid type 1975
