CFI Drip
Old Apr 6, 2016 | 10:16 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Default CFI Drip
While I was messing with my 82, I had the air cleaner off and was running the engine.
I was watching the injector spray and noticed that while both had the normal conical spray, there was the occasional yet steady solid drip of fuel. The car pulls a reasonable between 16-17 hg on the gauge and idles smooth between 650 and 850 depending on the engine temp.
The cars runs well so is the drip normal or is it a sign that something needs to be attended too? This is my first CFI so I'm not sure what normal looks like.
Thanks!
Old Apr 7, 2016 | 05:58 AM
awesome71vette's Avatar
awesome71vette
7th Gear
One of the injector o-rings is leaking and causing the dripping you're seeing.
Old Apr 7, 2016 | 11:11 PM
billschroeder5842
Thanks- I'll run that to ground and see what is up
To CFI Drip
