Performance Upgrade Poll
Old Sep 4, 2002 | 10:32 PM
C3at16's Avatar
C3at16
Default Performance Upgrade Poll
I have a 1978 shark and am looking to get some performance upgrading done. Which would you suggest or if other's please list them for me.
Old Sep 4, 2002 | 10:41 PM
Zack Wenning's Avatar
Zack Wenning
Default Re: Performance Upgrade Poll (C3at16)
We could give much better advice if you gave more info on your car. ie auto/4speed, rear end ratio, other mods already done
How much do you have to spend?
Aaron-74's Avatar
Aaron-74
Mild cam, better heads,free flowing exhaust, Holley and ignition. :yesnod:
Old Sep 4, 2002 | 10:42 PM
ROD NOCK's Avatar
ROD NOCK
I would install new dual exhaust first. Not only will you benefit from better 'breathing', but the new rumble will make you feel even better every time you drive it! Good Luck -Rod :chevy
Old Sep 4, 2002 | 10:54 PM
C3at16's Avatar
C3at16
well here are some things...the car was an L-48 but now has a L-82 in it. It is automatic trans. regular stock exhaust. Basically everything is stock on the car that I know of. I've got about 1,500-2,000 dollars saved right now, but of course I could always save some more and get the upgrades later. Just give me your suggestions and if you have approx. price tags on items you suggest that would be great.
Old Sep 4, 2002 | 10:57 PM
Aaron-74's Avatar
Aaron-74
True dual with headers- 400-600.00$ (depends on mufflers and headers)
CompCams XE-262 cam,lifter and spring kit- 300.00$ (I think)
Edelbrock Performer Air-Gap-200.00$
Holley Street Avenger 670-395.00$
Old Sep 4, 2002 | 11:04 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Headers and dual exhaust
Cam/lifters and cylinder heads
What are your goals/requirements. Do you want mileage, a lot more performance, medium perf.?
Old Sep 5, 2002 | 12:11 AM
tnt76vette's Avatar
tnt76vette
Default Re: Performance Upgrade Poll (burners)
True Dual Exhausts, A good street cam (My 260H is on the mild side, but still gave me a hell of a boost), a dual plane intake, and headers for a start. Get your Q-Jet rebuilt (cheaper and good enuff for the street), and let the Good Times Roll. :D . If ya want to go faster later you can always add a set of good heads. I can lite the tires now with stock heads...... :eek: :eek: :eek:
Old Sep 5, 2002 | 01:57 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Performance Upgrade Poll (Aaron-74)
Old Sep 6, 2002 | 08:54 AM
540 vette's Avatar
540 vette
Default Re: Performance Upgrade Poll (PrarieShark)
502 crate motor.
Old Sep 6, 2002 | 05:18 PM
vetteflame79's Avatar
vetteflame79
St. Jude Donor '06
Mild cam, better heads,free flowing exhaust, Holley and ignition. this is the trick
[img]file://localhost/Users/rogergro/Desktop/dscn0019.jpg[/img]
Old Sep 6, 2002 | 05:19 PM
Justin79-L-82's Avatar
Justin79-L-82
Default Re: Performance Upgrade Poll (540 vette)
If I were you I'd get a cam and intake, do some head work (the l-82 heads are already 2.02/1.60) headers, true dual exhaust. If your still not satisfied do some tranny work (shift kit, stall converter)
Old Sep 6, 2002 | 09:16 PM
warhovs's Avatar
warhovs
Cam and exhaust is good, but Holley and ignition wont do a bit of good for a relatively stock set-up, presuming you have the stock carb/ignition tuned correctly.
Old Sep 7, 2002 | 07:26 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
This is a hard question to answer. My advise, just keep doin upgrades till the money runs out. :cool: :cheers:
Old Sep 7, 2002 | 02:17 PM
nunus79's Avatar
nunus79
For an L82, work (mod) backwards starting with the exhaust and ending at the carb.
All smog motors, especially the L82, appreciates more cylinder pressure. Common way of building cyl pressure would be to raise the static compression ratio. A real quick, cheap, reliable way of building cyl pressure is to optimize your distributor's advance curve. You will definately feel an improvement if you are running stock settings.
Another good bang for the buck mod for an L82/auto setup would be a higher stall torque converter. Also, jump at any opportunity to get a higher gear ratio rearend like a 3.55-3.70.
I hope this helps and not confuse.
Old Sep 7, 2002 | 05:43 PM
QuickVet's Avatar
QuickVet
Default Re: Performance Upgrade Poll (nunus79)
new heads
Old Sep 7, 2002 | 10:36 PM
dogboy's Avatar
dogboy
Default Re: Performance Upgrade Poll (QuickVet)
R200 overdrive tranny with a better torque convertor and some rear gears. $ 2 grand should cover that. Better gas mileage, better pick up, and when you put the goodies in the engine you will feel it right away and not wish for these upgrades later on.
To Performance Upgrade Poll
Old Sep 7, 2002 | 11:36 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Performance Upgrade Poll (gb4622)
BTW, what exactly is a "full racing cam?" AFAIK that was a :bs term used by people who thought they knew cars
Old Sep 7, 2002 | 11:40 PM
Denney's Avatar
Denney
There is no replacement for displacement...
Old Sep 8, 2002 | 04:14 AM
Sting Raycin's Avatar
Sting Raycin
Default Re: Performance Upgrade Poll (Denney)
IMHO, Start with exhaust . It is a good per dollar mod, but every engine mod you do later will benefit from the better flowing exhaust too!
