1970 Battery Drain
Old Apr 10, 2016 | 10:16 PM
sboying's Avatar
sboying
Default 1970 Battery Drain
Battery is draining after 4-5 days.
I have searched this topic and have already checked the easy...
- Battery is new
- With car running battery is 14.47v and check at alternator is 14.51v
- Removed neg cable and check with multi-meter in series, it shows 0.08 amps
This seems low to be draining? Thoughts on next step(s)?
It does have an alarm(not sure if everything is hooked up), no power windows. The horn works intermittently, have to press it a few times.
Thx
Shawn
Old Apr 10, 2016 | 10:29 PM
65GGvert's Avatar
65GGvert
That's not a terrible drain. First check the common stuff. Are any lights staying on? Courtesy, storage compartment, rear? Is your radio stock or aftermarket? Is the clock running?
I think if it's draining in a few days with only .08 amps, I'd run by one of the parts stores and have them run a test on the battery.
Old Apr 10, 2016 | 10:35 PM
sboying's Avatar
sboying
after market radio. I just replaced the battery. Driver's door light switch is bad I know, have to pull it out for the courtesy lights to come on. No lights are on with the doors closed and battery hooked up.
Old Apr 10, 2016 | 11:13 PM
righthanddrive's Avatar
righthanddrive
Could be a bad battery. Not common, but it does happen. You could pull the fuse for the radio and see if that stops the drain.
Old Apr 11, 2016 | 12:31 AM
babbah's Avatar
babbah
Battery
Old Apr 11, 2016 | 10:10 AM
sboying's Avatar
sboying
Let me clarify on the battery. Drain existed on 3 year old battery and drain exists on 3 week old battery.
Old Apr 11, 2016 | 10:39 AM
jim in oregon's Avatar
jim in oregon
Check the owner's manual for fuse panel/which fuses on what components..
Identify which fuse is for the alarm system..Probably same one as the interior lights..
Check owner's manual on how to activate and DEACTIVATE THE FACTORY ALARM..
Quite possibly the components in the alarm system are not working but still drawing current IF system is in the activated mode.
Pulling the proper fuse for the alarm circuitry and then measuring the parasitic current draw will show IF the alarm circuitry-components are the bugaboo..
Not sure if my '78 alarm or fuse panel is the same as your 70 so you just have to run thru some fairly simple tests to isolate the issue.
With car completely off only current draw should be the electric clock..unless alarm is ON..or THINKS it is ON.... point 8 amps will draw down a good battery in 3 days.. fact that the old battery acted the same is indicative of some parasitic current draw beyond the electric clock..Make sure your radio is truly off with car completely off..jim
Old Apr 11, 2016 | 11:23 AM
MelWff's Avatar
MelWff
If the light in the center storage compartment behind the seats is working, make sure it is actually going off when the compartment door is closed.
Old Apr 11, 2016 | 12:02 PM
Revi's Avatar
Revi
You're halfway there.
Pull one fuse at a time and see when the battery stops draining. Then use your wiring diagram and see what components are associated with that fuse and continue trouble shooting from there.
Old Apr 11, 2016 | 12:14 PM
jim in oregon
One thing you didn't clarify was HOW MUCH IS THE BATTERY DOWN..WILL CAR CRANK SLOW OR JUST DEAD as a doornail?jim
Old Apr 11, 2016 | 02:27 PM
65GGvert's Avatar
65GGvert
He said .08, point zero eight.
An aftermarket radio with memory and clock will draw some current. Disconnect it or pull the fuse and check your drain again. Naturally the closer to zero the better. I'd pull the fuse for the clock and radio and check, then put one at a time back.
Old Apr 11, 2016 | 02:28 PM
sboying's Avatar
sboying
Battery was fully charged before checking
Volts & Amps.
Thx
Old Apr 11, 2016 | 02:29 PM
65GGvert's Avatar
65GGvert
You probably shouldn't worry about a light staying on, that would draw a lot more than .08, unless it's a backlight or something for your aftermarket radio. That's where I would start, with the radio.
If that's not it, I'd pull the plug off the alternator while monitoring draw, if it goes down you may have a leaky diode in the rectifier circuit in the alternator.
Old Apr 11, 2016 | 04:08 PM
68blvert's Avatar
68blvert
.08 amps is 80 milliamps. anything more than 50-60 milliamp draw will run a battery down in a few days.
Old Apr 11, 2016 | 06:19 PM
65GGvert's Avatar
65GGvert
I disagree with a few days, but doesn't matter. He still needs to find if something is bad, or if that's what his radio and clock are drawing and make a decision. 80 thousandths of an amp will take a while to run down a charged battery. If 40 lasts a month, 80 should last 2 weeks.
Old Apr 11, 2016 | 08:40 PM
sboying's Avatar
sboying
Removed radio fuse, draw is now .070(70 milliamps). So radio takes 10.
Noticed 2 purple wires left/front of fuse box that seemed to have lost wire-nut. I forgot to mention it has electric antenna as well.
Old Apr 11, 2016 | 08:45 PM
65GGvert's Avatar
65GGvert
That's pretty normal on a radio if it has station memory and a clock. Try the alternator plug and see what happens.
To 1970 Battery Drain
Old Apr 11, 2016 | 09:00 PM
sboying's Avatar
sboying
removed positive wire from alternator, still have .07 on meter. Clock is next.
Old Apr 11, 2016 | 09:11 PM
sboying's Avatar
sboying
removed clock/lighter fuse. Draw is ZERO. Guess I won't be able to smoke or tell time. Is this common for the clock?... kinda thought it was cool the thing worked.
Thx again!
Old Apr 11, 2016 | 09:13 PM
65GGvert's Avatar
65GGvert
That's really all that's left that should draw with the doors closed and everything off. Next up, pull fuses one at a time.
