Hello I have a 79 steering column that I purchased, its a standard column NO tilt or telescope with a plastic H style crap O steering wheel. Im looking to install a three spoke wheel and need to install a different hub to mount the new steering wheel. Has anyone changed or came across the mod and where to purchase these items.
Thanks Jeff
I am looking at my AIM, and I don't think you can install the hub on the shaft.
Everything is recessed deeper on the tilt-tele and you would probably need to change the horn assembly also.
Good luck. I agree that the tilt wheel is much better design. At some point during the year they discontinued the standard wheel, so it may be worth keeping as is
