Power Steering Control Valve
Old Sep 5, 2002 | 11:08 AM
Older Than Dirt's Avatar
Older Than Dirt
Default Power Steering Control Valve
I need a new steering valve. Zip seems to have the best price on a new one. I think I would rather have a new instead of rebuilt one. Any of you guys ever used one from Zip? Are they good quality? :chevy
Old Sep 5, 2002 | 11:33 AM
Swamp Thang's Avatar
Swamp Thang
Default Re: Power Steering Control Valve (Older Than Dirt)
yep, put a new one in last summer from Zip - no problems no leaks. Spend the bucks and put in new hoses as well.
Old Sep 5, 2002 | 01:25 PM
Older Than Dirt
Default Re: Power Steering Control Valve (Swamp Thang)
Thanks! New hoses sounds like a good idea too. :cheers:
Old Sep 5, 2002 | 01:34 PM
Cali,68,L-79's Avatar
Cali,68,L-79
i am on my third one!! :rolleyes: First was rebuild from Ecklers, second was new from Ecklers plus money back since 1st leaked before 90 day warranty ended. Latest is new PS valve from ZIP and it to is leaking from the gasket on top where the mounting bolt attaches to the idler arm (not sure name of part) P.S. I did not do the maintenance on the 3rd one so it's not my lack of mechanical skill. I am sick and tired of spending $100 every year for a P.S. valve. Screw it I think I'll just let it leak, good for the ecosystem anyway. :D
Old Sep 5, 2002 | 04:37 PM
Jim Shea's Avatar
Jim Shea
I'm not being paid by Vette Brake Products. However, they rebuild control valves and have a 5 year warranty. "New" valves that they sell only come with a one year warranty. What does that tell you.
Old Sep 5, 2002 | 04:42 PM
Milest's Avatar
Milest
Default Re: Power Steering Control Valve (Jim Shea)
Another satisified customer here with rebuilt one from Vette Brakes. I would also check the hoses and replace if necessary. Remove the left front tire and you will have easy access. Not a difficult job at all.
Old Sep 5, 2002 | 05:04 PM
gmcclurg's Avatar
gmcclurg
Older Than Dirt,
I tried to send you an IM, but that didn't work so if you can send me an email at gmcclurg@gillmarketing.com I just orderd my power steering parts from Zip and am pleased, but I can save you some money
Gil
Old Sep 5, 2002 | 06:03 PM
Older Than Dirt
Default Re: Power Steering Control Valve (gmcclurg)
You've got mail. :D
Old Sep 5, 2002 | 06:06 PM
gmcclurg's Avatar
gmcclurg
Sent an answer back, any questions, let me know
Good luck
Gil
Old Sep 5, 2002 | 06:10 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I bought one for a 79 corvette I had one time from ZIP. Never had any problems with it either.
This last time I rebuilt my own. I haven`t had the chance to use it yet because I don`t have the car on the road yet. :confused:
Old Sep 6, 2002 | 12:27 AM
mark79,80's Avatar
mark79,80
I purchased a new one from Zip products. It was manufactured by
Stainless Steel Brakes. After a little over a year and about 1000
miles it started leaking. I called Zip customer service and they
said they have more problems with the new ones than the rebuilt
ones. She was willing to give me full credit toward either a
new or rebuilt one. I tried a rebuilt one this time, so far no leaks.
Also great service from Zip to go beyond the warranty!
They also always give prompt credit for any core returns.
When removing a control valve look at how far it is threaded on
the relay rod. If the replacement is not threaded on the same
distance, the steering wheel will not be centered.
Old Sep 6, 2002 | 05:42 PM
Cali,68,L-79
Default Re: Power Steering Control Valve (mark79,80)
okay guys which one is better rebuild from Vette Brakes or ZIP?
Old Sep 6, 2002 | 11:43 PM
Steve Grodin's Avatar
Steve Grodin
Try The Last Detail. http://www.tld-corvette.com/ :chevy
To Power Steering Control Valve
