On my 68 convert, the S-shaped door hinge springs - to hold the door open - keep slipping down so the bottom part of the spring eventually does not contact the little rollers on the hold-open mechanism on the hinge. Any suggestions for keeping them up in proper position? I'm getting pretty good at using the special bent screwdriver installation tool.
The proper hold open springs for your careshould not drop down too far to where they are not engageing on the lower hinge detents.
Installing them requires a 12' flat blade screwdriver or similar tool with a 45 degree bend 2 " FROM THE TIP..Spring is put in place on the upper end and then screwdriver tool used to coax the lower part og the "S" to engage the detent and hole in the lower part of the door hinge..jim
ps there are some good ho to vids on utube and Wilcox and others sell the proper spting and tool if you are not handy..
Thanks, Jim. If your read my post where I say that I'm getting good at using the special bent screwdriver tool, it means I already have one and have installed the springs. The passenger side is OK, but the driver side spring drops down when the door is shut and tension is not on the spring. I believe the aftermarket spring does not have the "flat" on the end of the top part ground in the proper place to engage the slot in the hinge. When I have time, I'll remove it and file the flat so it fits. In the meantime I put a piece of gas line tubing over the spring to hold it in place.
2016 C3 of Year Finalist
New spring or old? Like you said about filing it flat so it sits properly, that could be a problem but something isnt right for it to fall down. Iit should always have some tension on it to stay in there
When loaded properly there will always be tension... The video above shows how to load the spring from both angles and should help Ron figure out the issue.. At least I hope so.
Thanks. The video, which I also watched a couple months ago, confirmed what I suspected. The "upper" part of the S spring on the aftermarket (Chinese?) spring is the wrong dimension. It is just a little too long to tap up far enough so the end will pop into the "D" slot. The top of the spring hits the inside of the fender and will not go up far enough. I have whacked it really hard to try to go the additional distance- probably only 1/16 inch- to get the end in the D slot, but it will not go. The passenger side is OK. Either that spring is a little smaller or there is more clearance between the hinge and the fender. I'll file the end a little until it fits. BTW- I did not buy the springs from Willcox. Probably should have.
Can you flip the spring over on the chance the other leg is a different length
In the video I talked about the china springs being too long.. The best thing you can do is just take a die grinder and cut off a tiny bit (about 1/8") and it'll seat just fine.
Willcox
"cut off a tiny bit (about 1/8") " Yep- that's the fix. I guess the Chinese were just trying to give a little extra with their springs.
RR- the other leg is a different length- a lot longer- so that makes it worse if you try to flip it. The Willcox suggestion to cut a small piece off worked. I should have laid the two springs side-by-side before I installed them. One of them worked, so that was the correct dimension and I might have been smart enough to trim the other one before installing it.
