Wiper Washer lube and setup?
I found a 'how to' on the wiper motor but not a pump at this stage anyway. Cars only done 31,000 miles and the seals were still covered in some form of grease so I'll see how I go for now if I can't test off car. I had a go at twisting and turning everything, as you do
, and have set up the sprocket wheel on top so the pin from the plunger shaft is on the right of the high piece underneath, is that correct?
https://www.corvetteforum.com/forums...-assembly.html
excellent break down of the Wiper Motor and its grease points.Now on the pump, this doesn't look promising though (not the same), 180deg out. Maybe Mooser can give me a heads up of correct settings if he is listening.
Cheers AL
PS pin is now on the left of the high piece as mentioned earlier.
The nice thing about using an OEM electric pump is it continues to pump as long as you hold the button in so it'll clean the windshield in about 1/10th the time.
Here is the arm in the captured position of the plastic cam (180 out of the park) ignore where it is on the housing as the motor wasn't indexed in the photo, only the plastic gear vs the arm
The pin on the arm should be pretty much point right in the middle of the green module and the capture recess opposite
M
The cam under the ratchet gear is what is pumping the pump by loading it up and then letting it snap back. Since that cam is indexed to the 4 pointed star cam on the inside, which is driven off the wiper pin, there is a relationship to when the pump happens as to where the wipers are on the windshield. But I think there's more than one pump per swipe
HIH
M
M
HIH
M
What I have done is removed the Pump assembly and found it in very good condition with the exception of the bullet like connectors (Blue, Yellow) which I have given a thorough clean and intend putting some carbon grease on for protection and conductivity.My question to you and with your experience is ... how would you set this Pump assembly up if you were personally fitting it back on the Motor assembly right now. Would you mind talking me through it as I don't like grinding, banging or pop noises.
You can turn this small gear by hand only till it reaches this position, then with the pump piston exposed, you can push down on the piston to get it over the raised part that it currently is resting against ... Thanks
Short answer
The ratchet gear needs to set all the way down and the little metal tab is what will run along the ramp/cam on the underside of the ratchet gear.
As you said, the pump piston needs to be depressed so the gear can drop all the way down. Yours looks correct. So far so good
The pin from the wiper motor
needs to be positioned into this hole/slot on the pump star shaped cam
In theory, it is supposed to be ably to "find" that position on it's own, mine didn't and I had to turn that star cam to allow it to go in when I married the pump to motor
When the wiper motor is running, the metal ratchet arm
is moving back and forth ALL THE TIME but can't grab the ratchet wheel because the second metal arm right under the electromagnet
sits against the ratchet wheel and holds the ratchet arm out a little so it can't grab the teeth.
When you press the wash button, the electromagnet moves the second arm back, allows the ratchet arm to drop and start grabbing the teeth. The top of the ratchet wheel also has a cam area on it and that keeps the second arm out for an entire turn and then it drops back in place and moves the ratchet arm away from the teeth again.
That cam cut out is here in the 7-8 o'clock area on the ratchet wheel
If your hearing popping etc when the motor is on but not the pump pressed, that second arm isn't set in the right place and it's not keeping the ratcheting arm away from the ratchet teeth. BTW it (the second arm) twists sideways slightly as the ratchet wheel rotates, that's what makes it so confusing to figure out how it lets the ratchet engage/disengage
Does that make any sense at all?
M
M
That tab you see way in the back, horizontal on the second arm is what will end up tucked in front of/under the ratchet arm preventing it from grabbing the teeth..
When the second arm gets pulled up by the electromagnet that horizontal tab lets the ratchet arm fall all the way down like you see here and engage the teeth.
The vertical tab on the same arm then rests against the side barrel of the ratchet gear and get held up until the gear goes around and that tab falls into the missing area on the top of the gear (7 o'clock on previous pic)
At the same time, the vertical tab is riding against the ramp/cam on the side of the ratchet gear and allowed to be pulled sideways as seen by
the shape of the hinge/pivot here.
That is ramp/cam is pulling the first arm out sideways beside the ratchet arm and when it lets go, it slips the horizontal tab back against the ratchet arm and prevents the ratchet arm from grabbing the teeth again.
Or something like that, it's been awhile
M
So in theory you should be able to place it anywhere and it will reset itself.
The 4 point star cam underneath needs to be indexed properly (pin in that one hole)
M
Check this out ...
This thread should answer quite a few questions if you check out the link as well, you are a Legend Mooser ... and Thanks to others as well.
