Heat shields
Apr 19, 2016 | 09:24 AM
Heat shields
Do 72's have under body heat shields ? If so does anyone know where to get them and/or part no's ?
J Mo
Apr 19, 2016 | 09:49 AM
72s have the tunnel insulation but do not have the under body, 69 was the last
year for that, you could add them from a 69 setup
Apr 19, 2016 | 10:51 AM
Question
Quote:
Originally Posted by
LT-1 kid
You mean I could purchase the 68-69 heat shield and install them on the 72 frame ?
Apr 19, 2016 | 11:45 AM
The rear of the shield are riveted to the frame but the front it attached to the plastic pieces that are connected to the firewall.
My guess would be you won't have those studs.
You can see it near the top of my picture.
Apr 19, 2016 | 12:11 PM
'72's have the pieces at the turned up part of the floorboards but not the flat part.
CC part numbers 33673 thru 33678 depending on Ac or not and plastic vs. metal.
Brian
Apr 19, 2016 | 08:11 PM
J Mo
yes you can, just get the few little bracket parts and your all set
Apr 20, 2016 | 05:56 AM
I got some from JEGS which attach to the exhaust pipes they are about 3 feet long . they are very effective
Apr 20, 2016 | 09:28 AM
Brian
Does CC mean Corvette Central?
Apr 20, 2016 | 09:59 AM
No.... I should have put CA.... Corvette America
Brian
Apr 20, 2016 | 10:39 AM
Brian
Thanks Brain !
Apr 20, 2016 | 01:34 PM
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
mrichi
Can you give us a part number ?
