Exhausting issue for my 82
Old Apr 19, 2016 | 08:05 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Default Exhausting issue for my 82
I'm doing the debate thing about making modifications to my stock exhaust 82 with the TPI.
I'm looking for a budget conscious upgrade for the Bad-A sound. Sure performance is great, but I'm old enough that I'm more interested in cruising without drone but sounding that I can go faster than I can.
Right now I have the factory "2 into cat, out to dual mufflers"
So do I....
Screw it and do a full, true dual and find the money (I have it)... or...
Delete the cat, and get mufflers that sound great...or...
just swap out the mufflers...or...
be thankful my current stock system is functioning properly and is paid for and put my money into other things (insert ideas here)
Thoughts?
Old Apr 19, 2016 | 08:21 PM
Rebelrob's Avatar
Rebelrob
Well, I am not sure how much or if any power was gained by going to a TPI, but I would put that money into pulling out that old slug of an engine and giving it a proper refresh/rebuild, something with some ballz...
The engine configuration, heads, intake, cam, cr, will play into how the exhaust sounds.
Then you can get rid of the stock exhaust and go with true duels.
That's what I did...
Old Apr 19, 2016 | 08:53 PM
Ydnar44's Avatar
Ydnar44
I think the last post miss understood your question. Put some flow master 44's on it, most people have no idea what's under the hood of an 82 vette. It'll sound bad a@$ rolling up to stop lights, and your only in it for maybe 250 bucks.
Old Apr 19, 2016 | 08:55 PM
jim2527's Avatar
jim2527
True dual front to back...if your gonna do it. Do it.
Old Apr 24, 2016 | 10:50 PM
billschroeder5842
The recommendation from my muffler guy is to do the full duals with 44's.
Anyone have a video of that set up and are you happy with it?
Old Apr 25, 2016 | 07:18 AM
Ydnar44's Avatar
Ydnar44
I have that set up, headers, h-pipe, 2 1/2 pipe, 44' s. I thought they would be to loud. But they were perfect for my engine set up.
Old Apr 25, 2016 | 08:12 AM
jim-81's Avatar
jim-81
I would recommend Magnaflows over the Flowmasters but that's just my opinion. I have them and love the sound. Yeah go with true dual system.
Old Apr 25, 2016 | 09:17 AM
golfboy's Avatar
golfboy
Default Exhaust opinion
In my opinion, get rid of the cat and go with a true dual exhaust system with an H pipe and a set of performance mufflers of your choice. That is what is on my 78 Pace Car and I love the sound.
Old Apr 25, 2016 | 09:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
True duals walker quietflow or dynomax super turbos
Dynomax offers a guarantee if you dont like the sound send em back who offers that hard to lose.
If youre worried about drone stay away from most aftermarkets just the nature of them.Typically the louder the exh is outside youll hear it inside too
Old Apr 25, 2016 | 12:01 PM
SwampeastMike's Avatar
SwampeastMike
Unless you're certain they are reasonably new, consider replacing all of the vacuum hoses before you do anything to the exhaust. I know that sounds strange but after doing such to my '79 the sound changed remarkably! Previously it sounded great at idle and while accelerating but there was an awful drone while cruising. Now the drone is gone and idling/acceleration sound better than ever. I do have true dual. No cat, no "H" pipe and unknown mufflers.
Old Apr 25, 2016 | 12:52 PM
Rebelrob's Avatar
Rebelrob
I have 44's with a 3 inch dual exhaust with H- Pipe.
Sounds very healthy.
Old Apr 25, 2016 | 03:34 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you have to pass emissions testing in your locale? If so, you're probably going to need the cat.
Old Apr 25, 2016 | 04:58 PM
terry82's Avatar
terry82
you have to decide how much you want to spend.the cheapest route is to put on the mufflers of your choice,and gut the cat.The most expensive is the tru duals .you can buy the tru duals at one of the corvette parts sites or you can have custom bent pypes.i have 2-1-2 with a turbo mufflers ,no drone.
Old Apr 25, 2016 | 10:41 PM
drwet's Avatar
drwet
Correct me if I'm wrong, but I think the '82 only has a single hole in the crossmember for the exhaust. To go to true duals, you'll need to change the crossmember. With that said, I still think true duals are the way to go. You ca buy a complete bolt on system from Corvette Central with Magnaflow mufflers if you want a little more noise.
Old Apr 25, 2016 | 11:33 PM
terry82's Avatar
terry82
both pipes go down the same side next to each other.or you can change the trans crossover then the pipes go strait out the back.money and time .how much work and money for stock motor.i would put the money into new heads with a good cam .then it would sound good however you did the exhaust.
Old Apr 28, 2016 | 01:45 PM
Flowmaster Exhaust's Avatar
0Flowmaster Exhaust
Former Vendor
As others have mentioned, you could go with a set of Super 44's. These mufflers will give you a pretty aggressive exterior and interior sound level. If you want to maintain a relatively aggressive exterior sound with a little less interior noise, Flowmaster 40 series Delta Flow mufflers will do it. We also have a 50 Series Delta Flow muffler that you can run. Flowmaster 50 Series mufflers feature internal resonance chambers that are specifically designed to reduce drone while still providing a moderately aggressive exhaust note. Feel free to give us a call at 707-544-4761 if you have any additional questions about your exhaust system or would like a specific recommendation based on your sound preferences.
Old Apr 28, 2016 | 02:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Edited
Looks like Op wants to leave it stock
Both brands posting sound completely different Id post up and see if a member in your area has either or so you can hear first hand and decide
Delta Flow 50s werent bad (better than the 4xseries) on resonance, beter than expected but its there do sound good at WOT
Everyone has different tolerance best to see for yourself so you only buy one pair. Sound clips on the web are hard to get the same idea as in person
Old Apr 28, 2016 | 03:15 PM
Magna_Flow's Avatar
0Magna_Flow
Former Vendor
You can never go wring with a good quality catback like our 16889 system. If you were trying to stick to a budget, a pair of our dual mufflers do wonders!
Old Apr 29, 2016 | 10:36 AM
0Flowmaster Exhaust
Former Vendor
This is excellent advice. Nothing compares to hearing a system in person.
To Exhausting issue for my 82
