push rods
Old Apr 23, 2016 | 07:25 PM
69FASTFUN's Avatar
69FASTFUN
Default push rods
I am about to install my pushrods and I discovered one end has a larger hole than the other. When I took them out I keep them in order of the cylinder that they came. The way I have them does the big hole go to the rocker.
Old Apr 23, 2016 | 07:37 PM
69FASTFUN's Avatar
69FASTFUN
Apparently I have only one pushrod with a small hole on one end and a larger hole on the other end.
Old Apr 23, 2016 | 10:36 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
My gut tells me that one is worn on the end and the hole is larger because the tip is worn down. How does that rocker look?
JIM
Old Apr 23, 2016 | 11:20 PM
69FASTFUN's Avatar
69FASTFUN
All of the pushrods have the same size hole but one it was kind of weird. I looked a little bit closer and there was a chip also. I am installing roller rockers in new aluminum heads.
Old Apr 24, 2016 | 07:29 AM
rdroket's Avatar
rdroket
I would put in new push rods just to be safe. JMO
Old Apr 24, 2016 | 08:02 AM
jnb5101's Avatar
jnb5101
I always put the larger hole at the rocker arm end. The small hole is always in line with the lifter, allowing constant oil feed. The rotation of the rocker arm would partially block the oil flow out of the push rod thru the small hole.
Old Apr 24, 2016 | 12:47 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
New alum heads and roller rockers? Yea good u caught the p-rod flaw. U will need hardened p-rods for the guide plates and need to fit them up also. U dont want them to rub but just a smooth movement/clearance in the guide plate slot. Also clearance the rocker arms to the vlv spring retainer and the stud itself. Look up crane cams or comp cams for this info/clearance. Myself w/new heads i would use a "checker tool" to measure for correct p-rod length.
Hope this can help.
Old Apr 24, 2016 | 01:46 PM
69FASTFUN's Avatar
69FASTFUN
Hope this can help.
I viewed a couple Utube videos and I will adjust the guide plates.
Old Apr 24, 2016 | 02:21 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If you have any question on the pushrods as far as the way they look.....throw them out and get new ones......
For guide plate.....you will need a hardened pushrod as already stated.
Trend makes 90% of the pushrods in any Cam catalog.....
http://trendperform.com/c-1149647-push-rods.html
Now is a good time to check geometry as well.....
http://www.speedwaymotors.com/Manley...-Stud,536.html
This is not the end all do all tool....but it will tell you if you are in the ballpark.
7.800 is stock length....but I have seen them anywhere from 7.700 to 7.900 on 23 degree stuff (stock).
Not preaching here...just go the extra effort here and be done with it....
Good Luck
Jebby
Old Apr 24, 2016 | 03:00 PM
babbah's Avatar
babbah
If the cam is new, then install new push rods.
Old Apr 24, 2016 | 04:46 PM
7t9l82's Avatar
7t9l82
I agree with checking the length and installing new pushrods. It's just cheap Insurance. Having guideplates makes hardened pushrods a necessity, other wise you will soon have metal shavings floating through your oil.
To push rods
