Restoration Advice
Old Apr 24, 2016 | 09:53 PM
Dougustus's Avatar
Dougustus
6th Gear
Default Restoration Advice
I recently bought a non-numbers matching 68 convertible. The engine needs rebuilt and I was thinking about pulling the transmission at the same time to have it checked out. I was not able to drive the car because the brakes were removed, however I was able to start it and put it in 1st and reverse. The clutch worked and it went into gear fine. I've read on the forum that it's a "bear" to pull them both together and I thought I should ask for advice. Would you pull the transmission?
Old Apr 24, 2016 | 10:33 PM
forman's Avatar
forman
I pulled mine out from the front with the trans … but when i put it back in i had to start it from the front then move the cherry picker to the side of the car as i dropped it in ..go figure
