radio poltergiests
It goes on/off on its own and seemingly without any outside cause (Bumps, movement, accessories powering up). I tried to open/close the fascia so I could get to the CD player and reset the system but nada. The radio stays mostly off and will just pop on randomly for a short amount of time.
I sat in my car this morning and the radio would just go on/off. One time I squeezed the casing and it came on?
I can't seem to replicate any type of pattern so as to begin to troubleshoot.
I'm going to go at lunch and reach around the console and see if the harness is loose.
Anyone else have anything like this happen?
Just to see, I popped the key in and "Viola" the unit is working again. I gave it several more ignition cycles and everything operates just like it did usually.
So... could the unit require an independent grounding source? That is the only thing I can think that could cause what I saw??
