Installed four rebuilt stainless sleeved O ring calipers and new pads. Now brakes sometimes squeal when driving and stops squealing when brakes are applied. What needs to be done to stop squealing?
To stop the squealing you must bleed the air that is still trapped in the calipers and/or brake lines.
I know these brakes can be difficult to bleed so I used a Motive Products pressure bleed system at 10 lbs pressure. I bled once tapping calipers to dislodge air, let the system sit overnight bled again the next day tapping calipers again. Brakes work great stopping with no pull. Pedal is firm- engaging with no slop in the initial pedal travel.
Not disputing your advice just don't know what more I can do to get air out.
It could be this too....cheap pads are squeak prone.
Can squeak and squeal too! Did you change brands or types of pads???
I usually will feather the leading edge of the new pads slightly, so they are not riding on the edge, to give them the ability to maybe seat across the face faster!
The Wagner pads I used the last time I changed pads came with a stick on insulator that went on the back of the pad. You can also get a permatex blue spray that goes on the back of the pad and does the same thing. The squeal you are experiencing doesn't come from the pad material contacting the rotor. It comes from a vibration between the pad backing plate and the metal pistons in the caliper. The two vibrate against each other and cause a high frequency squeal. If you were as old as me, you wouldn't hear the squeal.
Duane
If you choose to try putting something on the back of the pads, make sure it is a lubricant and not an adhesive. Anti squeal compound is usually an adhesive. As the pads move slightly when applied, and adhesive will cause the pistons to rock in their bores, eventually taking out the seals. A little grease on the back of the pads can help reduce the vibration between the piston and the pad that can cause squealing. I have used Never-Seize with mixed results. fact is, some pads nowadays simply squeal. Its a function of the material they are using. traditionally brake pads were made with asbestos. That stuff was always quiet. Now they use ceramics, and metals, and all kinds of stuff. Some of it squeals. You may need to try a different set of pads.
If you have bedded in the brakes and applied the anti-squeak pads on the back of the discs, try putting a small bevel around the outside edge of each disc. I use a file. I would not add grease to any part of the caliper or piston back. It will melt and cause problems. Likewise I would not use a sander or sandpaper on disc pads. You can embed sand from the paper into the disc and ruin your rotor. It is OK to sand down or break the glaze on a rotor as long as you thoroughly clean the rotor with brake cleaner. Good luck. Jerry
But I don't see a problem using these lubes on the backs because that is what is done on these new cars without problems! Naturally you want to use it in the proper amount and keep if to the backs of the pads! I use a bench grinder and a stone wheel to hit my pad edges for a split second of beveling!
