Solution for coil problem-Built a bracket.
Old Sep 5, 2002 | 08:48 PM
Aaron-74's Avatar
Aaron-74
Default Solution for coil problem-Built a bracket.
Well, I'll let the pics explain how it's built. Pretty simple really. Only took about an hour or two.
[IMG][/IMG]
Old Sep 5, 2002 | 08:49 PM
Aaron-74's Avatar
Aaron-74
Default Re: Solution for coil problem-Built a bracket. (Aaron-74)
The back two holes (for the firewall) are out of wack because I drilled them to fit for holes already there.
Old Sep 5, 2002 | 08:51 PM
PatsLs1vette's Avatar
PatsLs1vette
nice job aaron,i knew you would figure it out :cheers:
Old Sep 5, 2002 | 09:02 PM
Aaron-74's Avatar
Aaron-74
Default Re: Solution for coil problem-Built a bracket. (pats406nitrovette)
LOL...Thanks. I'm glad you all have confidence in me.
Old Sep 5, 2002 | 10:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's a pretty darn good job, I came up with a solution too :lol:
Bob Turner's Avatar
Bob Turner
:yesnod:
Yes, Sir!! Beautiful engine pics you posted a few days ago by the way!!!!
Bob :cheers:
Old Sep 5, 2002 | 10:22 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Solution for coil problem-Built a bracket. (Bob Turner)
Looks good Aron :yesnod:
Old Sep 5, 2002 | 11:26 PM
Aaron-74's Avatar
Aaron-74
Default Re: Solution for coil problem-Built a bracket. (MotorHead)
Damn, I always take the long roads.
Bob-Thanks for the comp. Lotsa hard work in that thing.
Old Sep 5, 2002 | 11:29 PM
Aaron-74's Avatar
Aaron-74
I'm going to have to drill a steel plate to go inside the whiper area againts the fire wall for the bolts to press againts. I don't think with the things added leverage and weight, I don't think thing fiberglass will hold.
Old Sep 6, 2002 | 04:51 PM
Bob Turner's Avatar
Bob Turner
Your welcome. It's good that you changed the mounting of the coil- thanks to the forum.
I did see a picture of a MSD coil in Hot Rod (I just got the issue on 09/05 so it is probably the Nov. issue) that was mounted horizontally like you had yours......
Post some updated pics when you are done with it.
Bob :cheers:
Old Sep 6, 2002 | 04:57 PM
Fevre's Avatar
Fevre
Guess I missed the reason why the stock bracket location would not work. Care to re-tell the tale?
BTW Holes already there are the best holes to use. :yesnod:
[Modified by Fevre, 2:58 PM 9/6/2002]
Old Sep 6, 2002 | 05:00 PM
Aaron-74's Avatar
Aaron-74
Was it the REAL clean 1st gen Camaro SS on the cover??I saw that one.
Old Sep 6, 2002 | 05:02 PM
Aaron-74's Avatar
Aaron-74
Default Re: Solution for coil problem-Built a bracket. (Fevre)
I never had a stock bracket. When I bought the car it has an Accel Super coil already mounted on the fire wall. When I got my new motor running it burned out somehow. So, I bought the Blaster and couldn't find the stock brackets anywhere...no I'm where I'm at now. :yesnod:
Old Sep 6, 2002 | 05:05 PM
Fevre's Avatar
Fevre
Probably help unclutter that area behind the carb anyways. I got all kinds of wires and hoses there.
Old Sep 6, 2002 | 06:44 PM
Aaron-74's Avatar
Aaron-74
Yeah, I'd really like to have a clean engine bay. I HATE having wires and crap cluttered all over the engine bay. I wish I had the time and money to hide everything in the firewall and glass my firewall to be smooth.
To Solution for coil problem-Built a bracket.
