roller rockers
Old Sep 5, 2002 | 09:56 PM
Robert Holtman's Avatar
Robert Holtman
Default roller rockers
I'm ready to move my RPM range up a bit so I thought I'd try some 1.6 rollers. My torque is a little much for a fairly light car with 3,70' (OK 3,82 effectively) but the specs on a ZZ4 say 355 horse at 5250. So with a bigger cam (basically what a ratio change on the rockers does) will move the power range up a little. Then if that isn't enough, I can always go to a single plain or better flowing heads. Anyway I was all ready to order the Chevy 1.6's from Jim Pace's when a Summit catalog came to the door. They have Crane 1.6's (I think they are better than Chevrolets) a lot cheaper. The only question I have is the Chevrolet ones are self aligning. Will the non self aligning work and are they a pain to align? I've never put in rollers, is it really hard to get right?
Thanks, your STUPID, but curious car guy,
BBBBob :seeya
Old Sep 5, 2002 | 11:58 PM
Aaron-74's Avatar
Aaron-74
Default Re: roller rockers (Robert Holtman)
I think you have to have the self aligning.
Putting in rollers is not different than any other kind of rockers. :cheers:
Old Sep 6, 2002 | 12:17 AM
jdunne's Avatar
jdunne
Bob,make sure that you check measure your pushrods with new rockers...you will usually need to change the p/rods if you are changing the geometry...Chevy Hiperformance mag did a recent article on this as part of their Bowtie Basics feature.....i have the paired shaft roller rockers which are self aligning...they are pedastal mount with lock nuts so you dont need guide plates or stud girdles..john :chevy
Old Sep 6, 2002 | 04:07 AM
Gleese79's Avatar
Gleese79
Default Re: roller rockers (jdunne)
John,
What brand rockers did you get? and where from?
I suspect my rockers are going to fail. have allready had them repaired.
Mine are Yella Terra platinum twin shaft. If i need to go to a diff brand I
still want twin shaft atleast. Id rather not have to import a full shaft
setup.
Cheers, Chris.
Old Sep 6, 2002 | 04:25 AM
jackson's Avatar
jackson
Robert:
Also consider Comp Cams Magnum self-align 1.6 roller tips pn 1418-16 ... AND ... their Pro-Magnum self-align 1.6 full rollers pn 1318-16.
Old Sep 6, 2002 | 05:41 AM
jdunne's Avatar
jdunne
Default Re: roller rockers (Gleese79)
Chris,mine are the Yella Terra,platinum also...mine have done 2000 miles with zero probs.....what was the issue with yours?....john :chevy
Old Sep 11, 2002 | 05:42 AM
Gleese79's Avatar
Gleese79
John,
The pushrod seats broke :/
I have new pushrods with the ball end on them and a new set of anti pumpup
lifters on there now.
I'm hoping i dont have any problems with them anymore but I still have my doubts.
Anyway time will tell.
Cheers, Chris
Old Sep 11, 2002 | 07:36 PM
SteveG75's Avatar
SteveG75
Bob,
If you don't have guide plates, you need self-aligning rockers. If you have guide plates, you must use non-self aligning rockers so that they are not fighting themselves.
The ZZ4 (as with all current GM crate motors) comes with self aligning rockers. Hence, they must be replaced with self aligning rockers. To go to non-self aligning rockers, you need to add guideplates (requires screw in rocker studs) and hardened pushrods (may be an issue in terms of length with the hyd-roller lifters).
Old Sep 11, 2002 | 07:47 PM
VetteNut72's Avatar
VetteNut72
Some may not agree with me but the General spends big bucks developing engine parts that have to stand up to the 4 or 5 year warrantee. I would recommend the GM 1.6 rockers even though they cost a little more. These rockers were used on production engines (I think LT4 - anyone?) and in my opinion, are a better quality part than aftermarket.
Old Sep 11, 2002 | 10:55 PM
American Boy's Avatar
American Boy
Default Re: roller rockers (VetteNut72)
Better pay a little more now than break down and pay anyway later.
Stephan
[Modified by American Boy, 9:56 PM 9/11/2002]
Old Sep 12, 2002 | 01:54 AM
LT1driver's Avatar
LT1driver
right on....the general usually gets it right the first time. :cheers:
To roller rockers
