my 78 won't start
Old Apr 30, 2016 | 04:32 PM
jsz31's Avatar
jsz31
Default my 78 won't start
Took the 78 for a drive this morning, it started fine ran around for a few hours then headed home. Parked it in the drive way and went and cut grass. When I went to start the car I have electrical power for everything but the car is dead. It wont even try to do anything. It sets 80 % of the time in garage, I do start it on occasion, I thought it was the "safety switch" that the auto trans lever is suppose to engage when in park but it seems ok as far as position and contact with lever , I'm lost
Old Apr 30, 2016 | 04:50 PM
'75's Avatar
'75
Have you tried shifting it to neutral and tried starting?
Old Apr 30, 2016 | 04:52 PM
jsz31's Avatar
jsz31
yes I did still nothing wondering if it may be the ignition switch
Old Apr 30, 2016 | 04:57 PM
jsz31's Avatar
jsz31
I replaced the ignition switch about 18-20 years ago could it have gone bad just setting for most of the time.
Old Apr 30, 2016 | 04:59 PM
'75's Avatar
'75
It could be the ignition switch, but more testing will find the issue. Do you have a test light or vom (volt ohm meter)?
Old Apr 30, 2016 | 05:04 PM
jsz31's Avatar
jsz31
yes both
Old Apr 30, 2016 | 05:06 PM
'75's Avatar
'75
Check to see if there is power to the start solenoid while holding the switch in start. If so, the starter is the issue.
Old Apr 30, 2016 | 05:11 PM
jsz31's Avatar
jsz31
Will do '75 but not till tomorrow or Monday , its been along day and I'm calling it quits for the evening (70 yr old body just cant take it like early days) I thank you for the info and will post what I find in next day or two. I have a show tomorrow so I need to get my 02 ready.
Old May 1, 2016 | 09:00 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It could be the solenoid is sticking in the starter. Try giving it a few taps and try it again. Chevy starters were notorious for this back in the day.
Old May 1, 2016 | 09:14 AM
jsz31's Avatar
jsz31
I replaced the starter about 8 years ago with one of those mini starter being the stock one was too close to the header. The car doesn't get driven probably more than 200 miles a year, surely it isn't the starter? But crazier things have happened. Thanks
Old May 1, 2016 | 10:34 AM
Peterbuilt's Avatar
Peterbuilt
Is the battery good or bad?
Clean and tighten the wires on the battery + and -.
Check that the battery ground connection to the frame is clean and tight.
Check that the battery wire at the starter is clean and tight.
Check the starter to frame ground is good.
This schematic shows the YELLOW wire brings 12 volts to the neutral safety switch with the key in START, and the PURPLE brings 12 volts to the starter.
Check that the purple wire at the starter is clean and tight.
Confirm that the NSS is closed in Park of NEUTRAL.
http://www.vetteprojects.com/bmv/mis...tte%201978.pdf
Old May 1, 2016 | 11:46 AM
jsz31's Avatar
jsz31
battery checked fine I even swapped another battery from another car I have , appreciate the schmatics, thanks
To my 78 won't start
