Road vibration under power
Old May 5, 2016 | 09:21 PM
stumpshot's Avatar
stumpshot
Default Road vibration under power
Installed a new 383 in the '75. Has a turbo 400 trans. At between 55-70 mph a vibration starts but the origin is hard to pinpoint, almost feels like a wheel in front out of balance. Slip it into neutral at the same speed and RPM and the vibration stops. Let off on the throttle at speed and the vibration stops. All 4 wheels just aligned and tires balanced after strut rod bushing replacement. New torque converter installed with engine (Continental, from SoCal) and new motor mounts.
Thoughts please.
Stump
Old May 5, 2016 | 10:04 PM
Steveshighperformance's Avatar
2nd Gear
Thoughts please.
Stump
If your 383" doesn't have a 400" damper and flex plate it will vibrate.
Old May 5, 2016 | 10:17 PM
cooper9811's Avatar
cooper9811
Please educate me, Steve. I see tons of new 383 internally balanced that run as smooth as glass. They do not require a 400 damper and flexplate.
Old May 5, 2016 | 10:19 PM
stumpshot's Avatar
stumpshot
The engine was built, balanced and dynoed by Smeding Performance.
Would a flex plate and damper only cause vibration under power?
Old May 6, 2016 | 12:15 PM
MelWff's Avatar
MelWff
you didnt specify the RPM but can you replicate the vibration by having someone hold the engine at that speed and checking your pulleys, belts, and fan.
the engine fan/clutch assembly is properly seated on the water pump pilot?
if you are running vacuum advance, disconnect it and plug the line and drive it. If the vibration goes away you have a timing related issue.
Old May 6, 2016 | 07:01 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Check the u joints. If you're loosing one all that mass under power will move and as soon as you ket up it calms down.
Old May 6, 2016 | 07:34 PM
fishslayer143's Avatar
fishslayer143
my guess would be a driveshaft issue... out of balance or bad u-joint
Old May 6, 2016 | 08:39 PM
croaker's Avatar
croaker
I'm watching this . I'm looking at a used stroker and this is the way my luck runs
Old May 6, 2016 | 11:10 PM
stumpshot's Avatar
stumpshot
Thanks to all for the thoughts. I'm thinking u joints also. The engine is 370 hp with 450 lb/ft of torque @3600. I confess to hammering the 90,000 mile u joints just a wee bit. Think I'll replace them all.
Thanks again!
Old May 6, 2016 | 11:17 PM
lvmyvt76's Avatar
lvmyvt76
he puts in neutral, and the vibration stops, so it would point to the engine?? rpm goes down and vibration goes away. BUT engine was dyno tested, but not hooked up to a transmission, etc., so ???
Old May 6, 2016 | 11:27 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Thanks again!
The bearing "cups" should be a tight fit into the mating holes in the yoke.
If the bearing "cup" slides into the yoke hole easily, the hole has probably stretched oversize which will cause the bearing cup/needle-bearings to fail much sooner.
To Road vibration under power
