Driveshaft U-Joint Yoke CAP
Old May 6, 2016 | 02:13 PM
Silver 7T8's Avatar
Silver 7T8
Default Driveshaft U-Joint Yoke CAP
What is the correct assembly procedure for U-Joint Yoke Caps?
Are "Equal-GAPS" on both sides of the CAP Correct?
-OR-
Should the "GAP" be only on one side thus increasing stability?
Please see attached Photo & illustration.
Than You for any & all guidance.
Old May 6, 2016 | 04:26 PM
MelWff's Avatar
MelWff
are you sure you have the correct cap?
http://www.mamotorworks.com/Corvette...-each-612548-1
Old May 6, 2016 | 04:39 PM
Silver 7T8's Avatar
Silver 7T8
Yes - The cap is part of a yoke assembly -
The yoke is from a Kiesler TKO 5-Speed drive shaft.
I believe that it is the same as a Lincoln Versalies 3010 yoke?
Old May 6, 2016 | 08:50 PM
croaker's Avatar
croaker
Are both ends the same?
Old May 7, 2016 | 12:10 AM
Silver 7T8's Avatar
Silver 7T8
Croaker -
I am assuming that you mean U-Joint size "front to back on the driveshaft? ---
When you ask "Are both ends the same?"
The rear U-Joint is larger - a 1330, it is held in place using
OEM Strap steel retainers (Not Forged CAPS) like the smaller Front-1310, that uses CAPS to retain the U-Joint.
All parts on this drive shaft are matched and correct.
Again, I am looking for the "GAP Locations" on the solid forged Front CAP yoke when torqued?
I believe that "leading-side of rotation" is zero gap and the "trailing-gap" has the open large gap?
Some of the Drag-Racers on this forum probably set their U-Joint CAPS using the specific method I am looking for.
Thank You for Your interest and attention on my question.
Old May 7, 2016 | 12:21 AM
croaker's Avatar
croaker
Over my head now. I was just wondering if both sides looked the same as if maybe machining was off.
Old May 7, 2016 | 06:28 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Are the internal surfaces of the yoke and caps clean and free of rust or debris? I don't think there should be any gap when torqued to spec.
Old May 7, 2016 | 09:47 PM
redvetracr's Avatar
redvetracr
Shafi Keisler strikes again, I wouldn`t use that yoke.
Old May 8, 2016 | 08:52 AM
drwet's Avatar
drwet
Both gaps should be the same.
Old May 8, 2016 | 01:04 PM
Silver 7T8's Avatar
Silver 7T8
Thanks "drwet"
I know that there must be a "gap or gaps" on a yoke solid-removable-cap design, or else there would not be the needed clamping-force to hold the u-joint firmly in place of the yoke. Just looking for information such as yours that you so kindly posted, again thank you.
Silver 7T8 / Larry
To Driveshaft U-Joint Yoke CAP
