Brake Bleeding on a 69
Old Sep 6, 2002 | 04:40 PM
Jester69Stingray's Avatar
Jester69Stingray
Default Brake Bleeding on a 69
Is there anything special I should know before I go bleed the brakes on my '69. Thanks.
Old Sep 6, 2002 | 04:41 PM
Swamp Thang's Avatar
Swamp Thang
Default Re: Brake Bleeding on a 69 (Jester69Stingray)
don't forget to bleed both the inner and outer halves of the rear calipers
Old Sep 6, 2002 | 06:38 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: Brake Bleeding on a 69 (Swamp Thang)
Also, make sure to follow the bleeding pattern (I think it's driver's side rear, passenger rear, passenger front, driver front, but you might want to look it up). Vette brakes is naturally a PITA to bleed. I use this trick, which clutchdust thought up--really works great: https://www.corvetteforum.com/techti...=132&TopicID=3
JB
Old Sep 6, 2002 | 06:53 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: Brake Bleeding on a 69 (JB)
I am A.S.E. Certified in brakes and on C-3 brakes I don't like to pump them. The way I do it is have one person open the bleeder and the other person pushes the pedal "once" to the floor. Then reclose the bleeder and let the pedal up slowly. When you pump the pedal vigorously or more than once it's easier to cavitate air in the master. I've never had a problem getting a pedal on any of the C-3's I've done. P.S. I like the P.V.C. pipe on the pedal, that's a good idea! :cheers:
Old Sep 6, 2002 | 07:45 PM
Turbo-Jet's Avatar
Turbo-Jet
Try to keep the car as level as possible, as air pockets are easier to remove from rear calipers.
To Brake Bleeding on a 69
