Help Me Identify This Wire
It was suggested to me by someone familiar with older car electrical systems, but not Corvettes specifically, that I could use the constant from the cigarette lighter. That sounded like a decent idea.
However, without going into the long story, I inherited this car from my mother when she passed away, and it had sat in her garage undriven since 1991. Point is, whoever had the car before her did some hacking of the wiring around the radio and the shifter column. They replaced the stock radio with a mid-80's tape deck (it's wires didn't match either) and I am amazed that thing worked the way it was installed. Plus, it also explains why the instrument panel never fully lit up at night when the lights were on. But I digress...
I've figured out most of what they did, but I am at a small loss on the cigarette lighter wiring. From what that other guy told me, I expected to find a ground wire and an orange constant wire attached to the lighter. However, when I pulled up the shifter console, all that was attached was a ground wire. This actually matches the instructions the old Haynes manual I have (also inherited from my mother) gives for removing/installing the lighter, as it only references removing a ground wire.
Near the lighter, there was an disconnected orange wire with a black female connector on the end. See picture of lighter illumination wire (left), mystery orange wire (center), and lighter ground wire (right) at this link: https://www.dropbox.com/s/5y0l1i78d8...43.54.jpg?dl=0
Should this orange wire have been connected to the lighter somehow? Or something else? The connector on this orange wire is the exact same as the one on the orange wire that hooks into the clock. I'd like to make sure this is the lighter wire and not something else, since I will need to cut and splice it to the new radio. I have no problem losing the cigarette lighter as I am replacing it with a combo USB/aux port that is made to fit in the lighter housing. If this is not to the lighter and I need to hook that up to something else, then does anyone have suggestions on how to get a constant 12v to the Retrosound radio?
Also, bonus points to anyone who can identify the disconnected pink wire/connector that is seen just to the left of the ground wire, next to the A/C control, as well as the purple/white stripe and pink/green wires coming out of the same bundle that the lighter wires are coming out of.
Thanks in advance!
Thanks in advance!
The lighter had a ring ground under the retainer as shown in the picture below.
Willcox
The fun of a hacked up wiring setup...
I am also still very curious why I have unconnected wires (the orange one with the black connector, as well as the pink one with the larger connector) in the housing.
Have you though about just running a memory wire to the fuse box? You can pick up 12 volts constant on the accessory lug.
Willcox
Willcox
Willcox
My best guess is the ring ground broke, and they just re-wired it to the bottom of the lighter, leaving the orange unplugged for some reason.
Of course, then the next big question is WHY they did all this. Hopefully this wasn't some convoluted effort to get around a short somewhere and by straightening everything back out to where it started, I am recreating the problem...
I don't have them all on the tech site yet but I'm getting closer.
Willcox
Yes... Yesterday was a long day for me Pete.
