Brake powerbooster help
Old Sep 6, 2002 | 10:06 PM
my74ls4's Avatar
my74ls4
Default Brake powerbooster help
I am in the middle of restoring a 74 454 . I am going to install tall valve covers and I think they will hit the booster. Is there another booster I can switch to or anything else I can do to avoid the valve covers from hitting the booster?
Old Sep 6, 2002 | 10:12 PM
flynhi's Avatar
flynhi
Default Re: Brake powerbooster help (my74ls4)
street rod suppliers sell a smaller vacuum booster. Another optionis a hydraulic booster - hydroboost.com
Old Sep 6, 2002 | 11:01 PM
bigvette1's Avatar
bigvette1
Default Re: Brake powerbooster help (flynhi)
The street rodder suggestion is good. Check the bolt pattern to the firewall on yours and compare to the replacement. Also, check the rod length of the booster to the brake peddle hookup for size. Hint - go to NAPA and do the measurements on one vs taking yours out.
Old Sep 6, 2002 | 11:14 PM
Corey_68's Avatar
Corey_68
Default Re: Brake powerbooster help (bigvette1)
The one for street rods retail around $300, This is what I plan to use when I switch to the tall covers. :cheers:
Old Sep 7, 2002 | 04:14 AM
groovyjay's Avatar
groovyjay
Hydrabooster is the solution, here's mine:
Old Sep 7, 2002 | 06:27 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Brake powerbooster help (groovyjay)
Got one too ey ;)
Where did you guys get the one w/ the flat mounting plate? mine has a larger plate w/ a bend on the top. Gonna have to redrill it to make it fit, no biggie. Just gotta love these hydroboosters ;) :D
Groovy, what fittings are those? They are AN adapters right?
[Modified by Twinnie, 4:28 AM 9/7/2002]
Old Sep 7, 2002 | 08:56 AM
Brutus's Avatar
Brutus
Default Re: Brake powerbooster help (Twinnie)
Now if I could get one over here in Australia I'd be happy. No luck locating a decent one while In the US (Fl) recently.....just my luck. :rolleyes:
Old Sep 7, 2002 | 10:42 AM
flynhi's Avatar
flynhi
Here are some street rod suppliers: http://www.zigsstreetrods.com http://www.ecihotrodbrakes.com http://www.chtopping.com
ww.kugelkomponents.com
I have no personal experience with any of these so I cannot recommend any - but this list will get you started.
Old Sep 7, 2002 | 10:57 AM
Jim Shea's Avatar
Jim Shea
There is a complete How-To article in the Nov issue of Vette.
Old Sep 9, 2002 | 02:20 PM
flynhi's Avatar
flynhi
Default Re: Brake powerbooster help (Jim Shea)
Just received a hydraulic booster from Paul at Hydroboost. The unit looks complete and professional. Instructions are clear and easy to follow. I hope to install it in the next couple of weeks.
Old Sep 9, 2002 | 02:21 PM
82dukman's Avatar
82dukman
it's a great article, just finnished it last night.
Old Sep 9, 2002 | 03:03 PM
James's Avatar
James
Default Re: Brake powerbooster help (82dukman)
I ran into this same problem when I dropped a BB 509 in my 69.
I'm running Jesell shaft mouted rockers so I had to use tall valve covers.
I tried all of those places for a smaller booster with no luck.
No one seemed to know or make anything no matter who I called.
Went back to manual brakes.
Of coasre manual brakes require a little more pedal effort but that did not bother me. I thought of the Hydra-boost thing but I have been trying to keep a stock look as much as I can.
Old Sep 10, 2002 | 11:11 AM
norvalwilhelm's Avatar
norvalwilhelm
Guys Hydraboost solves all your weak brake problems. Any unit from at least 82 to 94 from anything GM with a diesel almost bolts right in. They are very compact and extremely powerful. They are all the same mounting brakets, just the internal piston changes with truck size,
I didn't know thery were that hard to come by. My local wrecker has lots at $50 CDN each.
I recently shipped one overseas and it was about $120 CDn.
To Brake powerbooster help
