L82 Air Cleaner Help.
Old May 22, 2016 | 06:42 PM
Jared Lipson's Avatar
Jared Lipson
4th Gear
Default L82 Air Cleaner Help.
Hey Guys.
I was been searching the internet for a few days now trying to find out what involved in replacing the factory air intake in my 78 L82 with one of the round chrome style ones that everyone seems to have. I really can't find any info.
What is involved in replacing it? I thought it would jut bolt on but I am noticing there is some kind of sensor in the old style snorkel and there are 2 hoses and a vacuum line going from the factory air cleaner. one hose on each side goes into the headers and one goes into the back of the carb.
What I am wondering is what do I do with the stuff that is attached to the factory snorkle.
Is there a how to on how to install the nice style round ones?
Old May 22, 2016 | 07:20 PM
GUSTO14's Avatar
GUSTO14
Originally Posted by Jared Lipson
Hey Guys.
Jared, you might want to check out this link. The same question was asked and a lot of good info was provided covering a lot of different aspects of switching out the Air Cleaner.
https://www.corvetteforum.com/forums...n-c3-help.html
Oh yea, and welcome to the Corvette Forum...
Good luck... GUSTO
Old May 22, 2016 | 07:36 PM
Jared Lipson
4th Gear
Thats exactly what i was looking for. Thanks. I am still leaning towards keeping the factory style one and just getting a chrome lid for it
Old May 22, 2016 | 07:50 PM
GUSTO14's Avatar
GUSTO14
A chrome lid with your L82 valve covers will look terrific and you won't have to try to figure out how to incorporate all of the factory emissions stuff to another air cleaner.
Needless-to-say, with all of the underhood heat in the engine compartment of the later model C3's, there is a real advantage to the factory "cold" air intake.
Good luck... GUSTO
Old May 22, 2016 | 07:53 PM
SwampeastMike's Avatar
SwampeastMike
Actually the dual snorkel assembly seems to be an excellent cold air intake more than adequate for the engine.
Here's how the factory system works.
Both of the snorkels have a vacuum motor operated damper. In the bottom of the air cleaner is a thermostatic vacuum switch that closes with heat.
The vacuum connection is at the base of the carburetor.
With a cold engine at low speed both dampers are closed by vacuum. When closed, the front damper switches intake air to the "heat stove" on the driver side exhaust manifold via the connection and tube (often missing) at the bottom of the snorkel. The side snorkel is directly connected to the vacuum source.
As the engine warms the thermostatic vacuum switch closes which in turns opens the front snorkel damper allowing cold air intake.
During periods of heavy acceleration, vacuum from the carburetor base drops and the side snorkel damper opens.
From what I've seen people will pay FAR more for one of those original dual snorkel intakes than the cost of a chrome thing that doesn't even provide cold (ambient) air without a hood scoop.
Old May 22, 2016 | 07:54 PM
Jared Lipson
4th Gear
Thanks man, i'm gonna work on cleaning up the valve covers this week, hopefully then just ned some elbow grease. My car is missing all the vents and ducts from the factory set up, but i have them all on order.
Old May 23, 2016 | 07:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the 1981 stock chrome top lid. It may drop right on the 78.
To L82 Air Cleaner Help.
