80 L-82 Distributor cap?
Old Sep 7, 2002 | 08:57 PM
DEL BUCHANAN's Avatar
DEL BUCHANAN
Default 80 L-82 Distributor cap?
I changed plugs and wires today, scared to touch the distributor cap. Does it go on like it comes off ? Or should I leave this part to a mechanic? :confused: :rolleyes:
Old Sep 7, 2002 | 09:02 PM
Pete79L82's Avatar
Pete79L82
Default Re: 80 L-82 Distributor cap? (DEL BUCHANAN)
Very easy to change. Just four spring clips to remove/install it. Just be sure if you have to remove any plug wires to get it out of the way that you mark them so they can be installed in the same order.
