OEM vs Hurst Shift levers - Are they the same?
Old May 27, 2016 | 02:27 PM
jimkari's Avatar
jimkari
Default OEM vs Hurst Shift levers - Are they the same?
Are the shift levers that connect to a Borg Warner 4 speed transmission the same between the OEM shifter and the Hurst? I need to replace the 3-4 lever and also I want to change out the reverse lever to the original style with the lockout cable.
Thanks,
Jim
Old May 27, 2016 | 03:53 PM
gbvette62's Avatar
gbvette62
No. The stock Corvette shifter is a GM made piece, and there are no parts that I'm aware of on them, that can be interchanged with parts from a Hurst shifter.
Old May 27, 2016 | 04:33 PM
ddawson's Avatar
ddawson
Hurst is definitely different then the stock stuff.
Old May 27, 2016 | 06:20 PM
jimkari's Avatar
jimkari
Great, thanks guys, I really appreciate the quick response.
Jim
Old May 27, 2016 | 08:37 PM
Wee's Avatar
Wee
Be aware there are 2 different size slots on the GM shifter levers.
Brian
To OEM vs Hurst Shift levers - Are they the same?
