Starter?
Old Jun 1, 2016 | 01:46 PM
jspiv04's Avatar
jspiv04
Navigator
Default Starter?
I have replaced the ignition switch, starter, and battery in my 78. I am experiencing from a cold start, the car performs normal; but once I shut it down after operating it to normal temperature, it won't say nothing. I need help because I don't have a clue were to start.
Old Jun 1, 2016 | 03:33 PM
MelWff's Avatar
MelWff
are you stating when warm you have nothing, no lights, no radio?
are the battery cable ends in good condition?
did you check the ground connection under the battery compartment where the cable attaches to the frame?
Old Jun 1, 2016 | 04:00 PM
TimAT's Avatar
TimAT
And the short cable from the right frame/mount to the block.
Old Jun 1, 2016 | 04:05 PM
Knerf's Avatar
Knerf
sounds like a battery cable issue to me, check all the connections and after its running for a while and you see the issue grab them to see how hot they are.
Old Jun 1, 2016 | 04:16 PM
johnt365's Avatar
johnt365
I had this problem too and made the following changes.
1. Clean connection points on ground cable from block to frame on passenger side.
2. Clean ground connection from battery to frame.
3. Add additional ground from starter to frame
4. Added heat shield.
5. Installed 1000 CA battery
6. Removed heat shield and added new PMGR starter from 2000 cadillac escalade
7. Replaced copper clad aluminum battery cables with new larger copper cables.
I have headers in Texas and it always cranks now. #7 was the game changer.
john
Old Jun 1, 2016 | 04:45 PM
drwet's Avatar
drwet
Very common problem. Undoubtedly it has everything to do with old cables and bad connections and just not enough juice getting to the battery. The final solution for me was the switch to a modern gear reduction starter. I used one for a 1996 full size chevy truck. It works with the larger flywheel. Did the swap many years ago after years of chasing my tail, never had a problem since.
Old Jun 1, 2016 | 04:47 PM
jspiv04's Avatar
jspiv04
Navigator
I have power to radio, lights, etc., but car won't turn over once it's warm. I have replaced connections to battery as well. Ground connection is ok as well. I recently put headers on, is there a such thing as the starter being too hot?
Old Jun 1, 2016 | 04:59 PM
croaker's Avatar
croaker
Did this start after headers were installed or was it present before?
Old Jun 1, 2016 | 05:01 PM
jspiv04's Avatar
jspiv04
Navigator
After headers
Old Jun 1, 2016 | 05:09 PM
johnt365's Avatar
johnt365
Yes. Things get hot, resistance goes up and the old parts can't keep up. Checking the connections and replacing connectors may not be good enough if the cables are corroded inside. Moreover, copper coated aluminum doesn't conduct as well as solid copper, it is cheaper though.
When you check the grounds, I would get a dremmel and make new metal on the block and on the frame then wire wheel the ends of the cable and reattach. Then add an extra...
The newer starter that is mentioned here is smaller, lighter and more powerful.
Upgrading your cables will be the hardest and cost the most after a new starter but it will likely solve the issue. I used this guy http://custombatterycables.com/.
Hope this helps.
Old Jun 1, 2016 | 08:39 PM
drwet's Avatar
drwet
If you upgrade the starter, you won't need to do everything else.
Old Jun 2, 2016 | 11:20 AM
MelWff's Avatar
MelWff
1. Install a heat shield, http://www.summitracing.com/parts/mr...FRSPfgodiswAgA
2. Too much initial timing can cause this. What is your initial timing set for?
To Starter?
