69 Mechanical Tach
Old Jun 1, 2016 | 09:40 PM
dshawster's Avatar
dshawster
Default 69 Mechanical Tach
Ok so the tach works fine when the cable is engaged. It seems that the end of the cable that goes into the distributor is a bit worn and there is a good 1/4" of play back and forth along the cable to where it backs itself out of the drive and will stop working. The cable is not broken or bound up, when it stops working I can unscrew the cable and put it back in and it will work for a mile or two then stops again. Anybody have thoughts on this? Is there supposed to be something on the cable to prevent the 1/4" of play? I'm thinking of cleaning it and putting some lock tight on it to prevent it from coming out, not my first choice but I don't care to replace the cable if I don't have too. Thanks in advance.
Old Jun 1, 2016 | 09:59 PM
CanadaGrant's Avatar
CanadaGrant
A new Tach cable is really cheap compared to rebuilding the distributor or worse, the tachometer. I would try that first and go from there as a new cable is only about 25 bucks.
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'd probably replace the cable but are you sure there isn't any issue with the driven gear? Have you pulled the coupling and looked at the gear.
The run out on the gear should be .10 aprox..
The cable is reverse wound which will thrust the cable toward the tachometer but there shouldn't be that much free play and this is why I say I'd go with a new cable first. The cable will also pull in any excess grease on the cable so never over-lube the cable.
Willcox
Old Jun 1, 2016 | 11:20 PM
dshawster's Avatar
dshawster
Willcox
The distributor was rebuilt by a reputable member on the forum and has about 100 miles on it since so i don't suspect the distributor. By driven gear are you referring to the tachometer itself? If so I have stuck my head up there several times and cannot see much of the backside of the tach, I'm 6'4" 240 so it is quite cramped for me and thats one reason I'm not looking forward to a cable replacement.
Old Jun 1, 2016 | 11:27 PM
0Willcox Corvette
Former Vendor
Your not going to see anything.. The driven gear is in the distributor so if you are sure it's okay then I'd move to the tach cable. (I'd still check it regardless).
I'm 6-4 used to be 300 lbs.. lol. So I know that pain.. I'm now 200 lbs though diet and exercise and I've been a runner now for the past couple of years and go I don't miss the extra baggage. What is neat about this is I've got a horrible spinal fusion and I've been in this business since 1973.... so lets not talk about age..
Ernie
Old Jun 1, 2016 | 11:40 PM
dshawster's Avatar
dshawster
Ernie
Congrats, getting rid of that weight is the best thing you can do for you body! I'll look at getting the cable replaced as it sounds like the issue. Thanks
Old Jun 14, 2016 | 07:41 PM
dshawster's Avatar
dshawster
I replaced the cable and it solved the problem, I compared the length of the ends that go into the distributor of the old and new cable with them pulled all the way out. The old cable was about 1/4" shorter than the new one and it might have been worn down from not being inserted properly. You can it in the attached pic. The new cable was a couple inches longer than the old one but much more pliable so it went in easily.
Old Jun 14, 2016 | 11:21 PM
0Willcox Corvette
Former Vendor
To 69 Mechanical Tach
