header wrap: good idea or not???
Old Sep 8, 2002 | 03:20 PM
nitrocharger's Avatar
nitrocharger
Default header wrap: good idea or not???
I have two problems right now, starter soak and cold O2 sensor at idle. The O2 sensor is mounted about 10 inches away from #8 cylinder and reads about 0 volts during idle and will operate correctly (.1 to 1 volt) above 1200RPM. Since an O2 sensor has to be at least 600 degrees to work, it is cooling off at idle and getting hot again at higher rpms. I have hooker side exhaust. I'm thinking header wrap will solve both problems but there is a disclaimer in the product description that says the wrap may void manfacturers warranty. My warranty has long since been up but there must be a reason header manufacturers dont want you to put that stuff on. Any help?
Old Sep 8, 2002 | 03:31 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: header wrap: good idea or not??? (nitrocharger)
what it does it creates moisture under the wrap when hot to cold and back to hot again...thats whay they wont warrantee with it.itll actually rot out the header eventually.Ive run header wrap for 5 years to cut down on heat in the engine compartment .not sure what its gone to do for the oxygen sensor porblem but i installed a heated one 3 wire because ines at the end of the collector with long tube headers.also its greast of r when your changing plugs between rounds pipes wrap keeps you from burning your fingers and hands.
[Modified by pats406nitrovette, 2:32 PM 9/8/2002]
Old Sep 8, 2002 | 04:05 PM
1979toy's Avatar
1979toy
When you drive through water it soaks enough to give everybody around you a scare for a couple of blocks.
DO NOT let oil get on the wrap.
My single wire O2 sensor is mounted 27 inches fron the cylinder head and works fine. The distance from head to sensor is covered with header wrap.
Old Sep 8, 2002 | 04:06 PM
Matt Gruber's Avatar
Matt Gruber
i would try the wrap for a test.
might try leaving 1/8" gap between the wraps to allow for air circulation in a permanent installation.
or get a heated sensor if that doesn't work.
What is the A/F at idle? if it is too rich it wll be too cool. 13:1 is about right.
Old Sep 8, 2002 | 04:44 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: header wrap: good idea or not??? (Matt Gruber)
A cold O2 sensor will always give 0,45V , when it's hot it will have a different value. The ECM probes for the 0,45V to determine if it's warmed up or not.
Old Sep 8, 2002 | 06:35 PM
Arkansas Flash's Avatar
Arkansas Flash
Default Re: header wrap: good idea or not??? (Twinnie)
I ruined a set of headers by using header wrap. The wrap does absorb mositure and it will cause the the tubes to rust prematurely. If you need to get heat to the oxygen sensor use a three wire, heated version.
Old Sep 8, 2002 | 07:15 PM
PatG's Avatar
PatG
I have had header wrap on my car for over 6 years now with no ill effects. The headers I installed were actually used. I sand blasted and then high temp painted them. I peeked under he wrap just a couple of months ago when doing an oil change and the headers look just like they did after painting. The header wrap makes a noticable difference in underhood temperatures and an accedental touch when hot does not mean instant burn.
As far as starter heat soak I can't tell you if it will help or not. I had heat soak before and after the header install. Finally got a rebuilt starter with a heat shield over the selenoid and have not had a problem since. No O2 sensor on my car so I can't help you there.
Old Sep 8, 2002 | 08:33 PM
LT1driver's Avatar
LT1driver
I wouldn't use it on street car, have heard it promotes rust under wrap over time. :nonod:
Old Sep 8, 2002 | 11:32 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Ok, I have the same notion that you do on heat exposure, only I have a different approach. Instead of header wrap which apparently causes many other problems why not compromise and use Jet Coat on the headers and save the exhaust header from moisture and still run cooler in the engine compartment?
JIM th Southern Man
Old Sep 8, 2002 | 11:49 PM
Steve Straus's Avatar
Steve Straus
Default Re: header wrap: good idea or not??? (PROSOUTH)
Second Vote for Jet-Hot over Header wrap.
Old Sep 9, 2002 | 12:01 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: header wrap: good idea or not??? (Steve Straus)
I agreee with Jet hot too except that it co$$t$ a LOT more to coat a header than to wrap it!
To header wrap: good idea or not???
