Air condition sealant
Old Jun 3, 2016 | 06:58 PM
mpro71vette's Avatar
mpro71vette
Default Air condition sealant
I have a small leak in my air condition. I bought some air condition sealant and I'm wondering if it will work? I have a 1971 383 4 speed with air. Oh yea, dye was put in to see the leak.
Old Jun 3, 2016 | 07:03 PM
myoriginal77's Avatar
myoriginal77
Where is it leaking from ?
I'd recommend fixing instead of the sealant -
Frank
Old Jun 3, 2016 | 07:05 PM
mpro71vette
Frank
Somewhere near the evap. I am getting vintage air but I just wanted a temp fix for now.
Old Jun 3, 2016 | 07:17 PM
The13Bats's Avatar
The13Bats
This is one of those things that some will call hack job but remember when gm had to use barrs in the caddys that had engine head leaks?
I have seen this used in many cars and the key is more using the gauges and getting the correct amount of the coolant in there, the cool cans with a gauge are more a selling tactic to the novices out there,
It works pretty much on leaks that take a while to seep out the coolant if the coolant leaks out in a day or two it likely will not help too much,
Since you want to update/upgrade anyway try this stuff it will likely buy you some nice cold ac for a spell....
Old Jun 3, 2016 | 07:18 PM
hugie82's Avatar
hugie82
I've used it and the sealer works but you MUST use the sealer first and then follow with a fresh charge of freon. If you put the sealer in by itself, the sealer will seal the shrader valve on your AC.
Old Jun 3, 2016 | 08:06 PM
mpro71vette
Old Jun 4, 2016 | 04:03 AM
mpro71vette
Anyone else?
Old Jun 4, 2016 | 10:50 AM
mikem350's Avatar
mikem350
Assuming it was converted to R134, go ahead and try it. For a small leak it might work.
You said there is dye in the system...look for leaks at all the connections, like hose ends, comp front seal, etc. Of course a UV light may help. Leaks can show up as oil residue also.
To Air condition sealant
