Fuel pump not turning on!!
I have a 82 and I finally figured out what my problem was on it not turning over. It was the starter! So now it turns over but I still haven't gotten the fuel pump to turn on. So that's my next question and hopefully last!! What steps should I go through to see why. I checked the fuse box and it is good. I even tried this trick I read of by unplugging the oil switch behind the intake. And it still doesn't prime the fuel system. Any suggestions??! I'm so ready to finally get it started.
Zen Vet Master Level VII
I have an '82 as well...
When was the last time you had the car running?
If you have a helper, put your ear on the open gas tank while he turns the ignition on. If you hear a soft whir/buzz then your fuel pump has engaged.
If you are getting voltage at the wiring harness and with your key in the "run" position and cant hear a buzz, thenext thing to do is to pop out the fuel sending unit with the attached fuel pump.
If the pump is bad, PLEASE consider getting the 85-89 fuel pump-- the higher pressure will make your car happy.
The car has never ran I bought it in pieces. Ok this is weird all if a sudden my fuel pump is working!! Lol but I'm not getting fuel to the engine. I took the line off to the fuel filter and its bone dry. What do I do now??
Sorry, I'm a bit confused...
If your pump is working as you say, then it should pull fuel from the tank and push it up front.
If you pump is working and you are not getting fuel moving, could your fuel lines be clogged?
