1980 corvette tach issue
Old Jun 6, 2016 | 01:12 PM
RayVette2's Avatar
RayVette2
2nd Gear
Default 1980 corvette tach issue
I am new to forum and would like to first say hello. next get some advice. I have a 1980 corvette that has recently developed a non working tach. I have troubleshoot the unit according to a guide by Willcox corvette. I am getting power to the lugs behind the unit along with a good ground and continuity on the 3rd lug which is the signal lug. Also when I turn the key on the unit zero's itself our. the circuit board looks good, no dark marks. The distributor is giving out a signal since I put it on an external tach and can see the RPM's. I then used the same wire, going around the tach filter and still no movement on the inside tach. What now? Help!!!
Old Jun 6, 2016 | 02:49 PM
JimLentz's Avatar
JimLentz
Bypass the tach filter and see if the tach works that way.
Old Jun 6, 2016 | 04:44 PM
RayVette2's Avatar
RayVette2
2nd Gear
Thanks. I have and even with a known source for the tach, because I hooked the wire to an external tach it still did not work
To 1980 corvette tach issue
