Finding An Electrical Draw - methodology question!
Old Sep 8, 2002 | 07:55 PM
lbell101's Avatar
lbell101
Default Finding An Electrical Draw - methodology question!
Hi!
Now that I'm not using my 71 as much I'm finding an electrical draw on the battery during storage. After a couple weeks it is stone dead. I put a new battery in it and I now disconnect it during storage but I'd like to fix the problem anyway.
As I understand it, if you disconnect the neg bat cable and put a meter between the post and the cable - you should see no or nearly no voltage. On mine, my meter shows 12 volts so I'm assuming that is confirmation of a draw. Correct??
Right now I have ALL the fuses out of the fusebox and I still show 12 volts at the neg cable.
Is this method correct for finding a draw??
If so, where else should I be looking besides the fused systems?
Thanks!
Old Sep 8, 2002 | 08:20 PM
GTR1999's Avatar
GTR1999
Default Re: Finding An Electrical Draw - methodology question! (lbell101)
Hi Larry,
I think you got the method down, now you have to find the problem. I don't have a schematic in front of me but a couple of things to check.
1- Is the wiper door up? I had a drain on the system when the micro switch was made by the wiper door.
2- Any aftermarket alarm or radio? Found draws from both on different cars.
Keep us posted on what you find.
Gary
Old Sep 8, 2002 | 08:22 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Finding An Electrical Draw - methodology question! (gtr1999)
your alternator can draw too ,just one more thing to check
Old Sep 8, 2002 | 08:31 PM
shoptek's Avatar
shoptek
Larry,
I might be wrong but.....shouldn't you be measuring amps being drawn thru NOT voltage???
My basic electronics knowledge is fuzzy :yesnod:
Old Sep 8, 2002 | 08:36 PM
andyg's Avatar
andyg
Use the meter to measue amps (Highest setting possible). Place black lead on neg battery post, place red lead on disconnected neg cable. I found my vehicle was drawing .3A when off and all doors closed. I traced it back to a bad alternator with a bad diode that was leaking back to ground. After replacing the alternator my draw was ~.01A Good luck....
--Andy
Old Sep 8, 2002 | 08:38 PM
Frank75's Avatar
Frank75
Default Re: Finding An Electrical Draw - methodology question! (shoptek)
Yeah, you need to put your meter between one of the battery cables and the battery post it came from, make sure you select the highest "amp" range possible and see if you can read something.
Old Sep 8, 2002 | 08:48 PM
Ingar, Norway's Avatar
Ingar, Norway
I would say that method is not usable.
Due to the very high input resistance of your meter even the smallest load on the battery (f.ex. clock) will make it show 12V. And it will tell you nothing about the magnitude of the leak.
You need to use the same hookup, but set the meter to measure current (Amp).
Be careful though if your meter doesn't have a built in fuse. Most cheap meters are unfused on the high current (10A) setting.
If you have a large leak or you make a short you might fry the meter.
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I agree Alternator diode likely culprit.
Old Sep 8, 2002 | 09:44 PM
lbell101's Avatar
lbell101
Default Re: Finding An Electrical Draw - methodology question! (Smokehouse69)
Thanks guys!
Amps - damn, I should have figured that one out.
None of my testers have full amp capability (mA only) so I rigged up a test light from a taillight bulb and some wires. The only time it will light is when the courtesy fuse is put in. So it's that circuit I believe.
Also, it was getting dark while I was doing this so I was able to notice that the interior lights sometimes come back on. This is after the door is closed for 10 minutes or so. So I'm pretty sure that must be the problem!
Thanks for the help!!!
Old Sep 8, 2002 | 11:13 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Larry, I had this problem years ago with a Nissan pickup. A battery killing draw in the courtesy circuit. The culprit was the delay box for the courtesy light. A friend of mine had the same problem, it was a light bulb thats filament was touching ground in the bulb, but not lighting. In your case I would also check for a door switch making contact at times when the door is closed.
And I would go ahead and keep useing your method to check for draw. Although a DC amp meter would be best, sometimes they are hard to come by and not necessary in this case. Just eliminate your known draws (clock, radio memory) so you dont get thrown off.
[Modified by 71,454,4spd, 9:16 PM 9/8/2002]
To Finding An Electrical Draw - methodology question!
