Cant open drivers door
Old Jun 10, 2016 | 02:59 PM
dwnissen855's Avatar
dwnissen855
4th Gear
Default Cant open drivers door
Ok, I know this has happened to someone out there. Mind sharing how you got open. I'm about to give up. Thanks in advance.
Old Jun 10, 2016 | 03:15 PM
blue by you's Avatar
blue by you
slim jim down the window and pull up on the latch
Old Jun 10, 2016 | 03:20 PM
C6Sal's Avatar
C6Sal
When my battery died, I was able to open the back with the key and climb in and pull the emergency handle on the floor next to the seat.
Old Jun 10, 2016 | 03:21 PM
bradleyb66's Avatar
bradleyb66
I seem to recall some people using something like a slim-jim to trigger the door mechanism, but when my passenger door got stuck on my 79, I removed the door panel (which is also sort of tricky, as I seem to remember one of the screws being 'hidden' when the door is closed). My problem ended up being an issue with the 'lock' not dis-engaging completely (and actually still has issues some days).
For searching for forum threads on the topic, I've had better luck using google, and adding 'corvetteforum' to the search topic. Something like 'corvetteforum c3 door won't open'
Good luck.
Old Jun 10, 2016 | 06:36 PM
Iceaxe's Avatar
Iceaxe
Here ya go....
https://www.corvetteforum.com/forums...-corvette.html
Old Jun 10, 2016 | 06:40 PM
AboveTheLogic's Avatar
AboveTheLogic
Attachment 48362474
Old Jun 10, 2016 | 07:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
No Saws All needed..
Old Jun 10, 2016 | 08:53 PM
AboveTheLogic
That reminds me I need to order a new door striker from Willcox
Old Jun 10, 2016 | 09:02 PM
0Willcox Corvette
Former Vendor
To Cant open drivers door
