78 AC Recharge (R12 replacement?)
https://www.amazon.com/RED-TEK-Refri...12+refrigerant
Any thoughts? Also, should I add an AC stop leak to be safe? I typically hate doing those types of things (for obvious reasons), but I don't use the car enough to justify a major AC rebuild. Thoughts are appreciated!
that redtek stuff according to their msds is 100% alkanes. Alkanes are flammable hydrocarbons, mostly methane/ethane (natural gas). I would not use it.
To get the moisture out it requires drawing a vacuum on the system for a period of time to allow the water to boil off. Harbor freight has a vacuum device that can be used with a decent compressor to get a vacuum.
http://www.harborfreight.com/air-vac...ors-96677.html
I used one of these for several years and it works pretty good as long as you have a good air pump that can run for 20 to 30 minutes straight.
The filter/dryer may be saturated, or it might not, hard to say. Usually it is replaced to be certain it is not obstructed.
Then you got to wonder why it's empty in the first place. Typical is the seal on the pump shaft is bad. You may fill it, but it will most likely leak out again. How quick depends on how bad the leak is.
That red tek R12 looks to be possibly a good replacement for R12. I would not be concerned about the flamability of it, gasoline is far more flammable and it sits in an open carb on these cars.
If it's worth the gamble to you go ahead and get the vacuum pump at a minimum in an attempt to get the moisture out, then fill it and see what happens. It might work, or you might just be out $75.
Otherwise you'll need to spend the $$ and/or time to get it fixed.
I've seen lower head pressures and lower vent temps using these types of R12 replacements.
The Gov. is making it harder to get these in the US, they are used widely oversees,
Neal
I would suggest fixing it correctly but i understand your position
Neal
This kit has both those. It will screw onto your r-12 fittings and also has 134a fitting that come with it.
http://www.harborfreight.com/ac-r134...set-60806.html
Or you can try to source them separately.
I'm in Flemington, if your certified its very easy to get, but expensive. I just bought a case off Ebay.
The thing that most fail to realize is that R134 is not as efficient as R12....so in an A/C system that was designed for R12.....it will not work as well.....
A friend gave me three cans and I will be using the Vacuum pump....
It will work fine with 134......but you will not be able to hang meat in there.....
Jebby
Jebby
Mine was 134a converted when I bought it. It had the stock cooling clutch fan and the only thing done in the conversion was to add 134a charging ports.
It was kind of cool, but not nearly what it should have been.
I decided to put in additional insulation in the floor, convert to electric fans with a new radiator, put in a C4 blower and add two shutoffs to the heater core.
The electric fans made a significant difference in the temperature of the air flowing from the vents.
The C4 blower made a significant change in the volume of that cool air getting delivered to the cabin.
The insulation under the carpet created an effective barrier against heat from the outside and the engine compartment.
I first only put in one heater core shutoff valve and the heater core still got hot over time, adding unwanted heat to the cabin. The second shut off on the other hose eliminated that source of heat.
Now it is a meat locker in the cabin if I want it to be. My wife, who likes her A/C, will complain of it getting too cold if I don't cycle the a/c off periodically.
Jebby
