Top end performance question
Old Sep 9, 2002 | 03:55 AM
Maurice's Avatar
Maurice
Default Top end performance question
I have a question about the top end performance of my car. I seem to be losing power at the higher RPM's and especially at higher speeds and higher RPM's. What would be some things to check into to find out what the heck is happening. My gut feeling is telling me it is my fuel pump isn't big enough to supply the amount of gas required. Any suggestions or anybody know how to tell if my fuel pump isn't big enough? My engine is a 502ci/502hp Chevy crate engine.
Thanks in advance
Maurice
Old Sep 9, 2002 | 04:09 AM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: Top end performance question (Maurice)
Mount/tape a fuel pressure gauge to the inside of your cowl hood scoop where you can see it through the windshield and attach it to a "T" in your fule line at the carb.
More probable in my opinion is that you may have the same problem Jay, Tom, me, and certainly many others have had: A throttle bracket that has slipped at its rear left carb stud. Jay's cost his L88 about 50hp during his dyno run before he found it. I think it cost me 70hp when I compare my first Dyno Day to my recent 483rwhp Dyno Day. Your symptons are just like ours were.
Chuck
[Modified by Chuck Harmon, 12:09 AM 9/9/2002]
Old Sep 9, 2002 | 01:12 PM
Maurice's Avatar
Maurice
Default Re: Top end performance question (Chuck Harmon)
AH HA! It wasn't the throttle bracket that slipped, but the throttle cable wasn't set correctly, I think it was only opening about 1/2 way. I haven't had a chance to go and run it yet, but I definately think that is a HUGE part of the problem. I must resist the urge to go start it at 6am...I must resist...I must resist....Neighbors will not be happy... :D
Old Sep 9, 2002 | 01:15 PM
Fevre's Avatar
Fevre
Same thing on my small block, the bracket has slipped. Not sure what it cost me at the track but sure it did not help.
Old Sep 9, 2002 | 04:07 PM
Maurice's Avatar
Maurice
Default Re: Top end performance question (Fevre)
Well, I just got back from my test drive. Definately a HUGE improvement, I now have the top end acceleration I was missing, also picked up quite a bit lower end power that wasn't there before but knew that I should have. I am happy again.
Old Sep 9, 2002 | 04:09 PM
Fevre's Avatar
Fevre
:cheers:
My carb was so out of tune I am not sure what I picked up but I know it runs like a champ now and opens fully.
Old Sep 9, 2002 | 04:42 PM
Chuck Harmon
:cheers:
Chuck
Old Sep 10, 2002 | 12:53 AM
Maurice's Avatar
Maurice
Thanks for the tip on where to look.
If you want to see a blurry 1/4 mile video that has my car in it for a second or two, here ya go. http://home.hawaii.rr.com/sswim/movies/Z06-69-1.wmv Details on the race: I lost, yes after that lead I lost, that is the no top end power I was talking about. I ran a 13.8 at 95, the Z06 ran a horrible 13.4 at 110, he usually runs 12.9s but our track was very slick this weekend.
To Top end performance question
