The coolant is full I tried to burp the system by letting it run without the rad top but coolant starts to come out as soon as it warms up...any better way to burp it
This tells me your only problem is that you still have trapped air in the system. The way I used to burp the system was to get the front up on ramps so the radiator cap is the highest point in the system. Sometimes it takes a while, but it will burp.
As for a better way, get yourself an "Air Lift" fill tool or a cheap copy like the FJC-43610. No more trapped air with these thing. They work by vacuum, so not only do they purge the air, but will also indicate a coolant leak somewhere if you can't hold a vacuum in the system. You need an air compressor though.
Could be intermittent sticking. Seen plenty of that before. The fact the OP never see's water circulating but rather spilling out the top is a sign of blockage...and with everything else being new.....
so it would only stick at idle never while moving?
I have seen intermitted sticking but not that discriminating.
so you doubt the sticking stat is doing this?
So trapped air in the system would allow it to cool while moving yet overheat while at idle,
[QUOTE=The13Bats;1592447426]so it would only stick at idle never while moving?
Doubtful, but anything is possible. I've only encountered one stuck thermostat in my life. The only way to know for sure is pull or replace it and see what happens.
Very possible depending on the amount of displaced coolant. It would likely still run hotter than normal at speed though. The OP said it was doing "pretty well". Is "pretty well" a nice consistent 180 or 220?
How old is your Rad? Please show us a pic of the fan shroud you have. I bet that the shroud is your problem if you have all the other seals and dams in place, and your rad is newer.
The importance of the fan shroud covering the whole radiator in these cars cannot be ignored, this system needs the whole radiator to contribute to cooling, and if it's not you will get overheating troubles, especially in the hotter climates.
Hi,
been busy with my '73 454 and now that summer is here it doesn't like the heat...it overheats very easly at idle but does pretty well when going.
I've had the 454 rebuilt with a bigger cam and intake and I have the transmission cooled by a separate cooler w/fan.
On a hot day temp. will get up to 250 and idle and Im really concerned about ruining the engine.
I have all the required radiator shroud, bottom bumper spoiler, even added Hyperlube super coolant additive but Im afraid that the all set up is so tight under the hood and there is not enough air flow
The only other thing is to add a radiator fan ...any suggestion on how many and what brand? ...they all look the same to me )
here's my set up:
cheers
When Chevy engineers decided where to locate the sensor for the temperature gauge, they placed it at the absolute hottest place on the entire 454 engine- right where the coolant has just come out of the engine and right next to the exhaust manifold. I moved the sensor to the top of the intake manifold where the coolant from both sides of the engine has mixed to a uniform temperature and is about to go back into the radiator. This is where many other engines have their temp sensor and is a more representative measure of the overall coolant temperature, rather than a localized reading at the engine's hot spot. If you get a 250 degree reading here, you do have a real problem. There will be a difference of about 20 degrees between the two locations. Purists will hate this idea.
I learned this sensor thing myself on my 454,
In all due respects to purists just because the factory did it a certain way doesn't make it the very best, another reason I was never into factory stock I like to have the room to improve, update and upgrade things...
Before my engine swap my 454 ran 180 all the time regardless of outside temp. If I got on it real hard it would heat up one needle width on the gauge. After the ZZ454 went in it would run 180 on the road but at idle would creep up into the 210 range. All my seals were in place and I attributed it to the higher comp ratio and aluminum heads giving off their heat to the coolant more rapidly. I added a Spal slim 16" pusher on the front/left side of the radiator. I used a Derale controller set to come on about 185-190. It will cycle on and off now in stop and go traffic and never runs when moving. Total cost about $150
Fan Spal Electric Fans IX-30101517 from Summit Racing. This one is thin enough that the hood will not hit it when you open the hood.
Controller Derale 16759 adjustable controller. This controller switches the ground to operate the fan. The fuse is on the negative side of the fan wiring. I put it on the positive wire. I used the green a/c wire to switch fan on from inside the car manually.
Nice...did it do the job and kept your 454 under 200 degrees?
I like what Im hearing but it never did that before this summer ...it always stayed at 180 ...should I be worried? Should I burp the rad by letting engine run with no rad top to make sure no air is causing this?
