LSx Engine Upgrade for 1975 Corvette
Old Jun 20, 2016 | 03:25 PM
jteel01's Avatar
jteel01
3rd Gear
Default LSx Engine Upgrade for 1975 Corvette
Hello all. I'm new to this forum. I'm contemplating purchasing a 1975 (engineless) Corvette, and am interested in learning more about what it takes to convert to a LSx motor. I've seen some dated posts on this for LS1. Wanted to inquire if there may be some more updated info. Any guidance is much appreciated.
Old Jun 20, 2016 | 03:43 PM
bluedawg's Avatar
bluedawg
The info is still accurate and I'd be willing to be that the folks that did it would be willing to answer questions via pm.
Old Jun 20, 2016 | 04:11 PM
jteel01's Avatar
jteel01
3rd Gear
Bluedawg, thank you for the prompt reply. I've seen references to a "sticky" on this topic for LS1, but cannot see the sticky. Can somebody point me to this?
Old Jun 20, 2016 | 05:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Did you want a carb on it or EFI
Old Jun 21, 2016 | 12:53 AM
bluedawg's Avatar
bluedawg
Try these out, they are in the consolidated sticky, what happened to my sticky thread. I wanted to do an ls7 or ls9 swap, pretty daunting task back then but seems that there are kits for about the hole swap, the erod is a stand alone system with an electric gas pedal and all, seems like a good set up for 425 horse and not overly expensive, back them piecing it all together and the tuning it with the computer. Ive tunned many of small blocks with jets, timming and all and im sure once you get all the computer stuff figured ot it wouldnt be that bad. Have you seen the ls/twin turbo thread by boosted C3? Looks to be a bad *** vette.
https://www.corvetteforum.com/forums/c3-tech-performance/2226401-c3-lsx-conversion-directory.html
https://www.corvetteforum.com/forums/c3-tech-performance/1765292-who-out-there-has-actually-swapped-an-ls1-ls2-ls6-into-their-c3.html
Old Jun 21, 2016 | 11:18 AM
jteel01's Avatar
jteel01
3rd Gear
Thank you. Time to start reading! I'm most interested in EFI.
To LSx Engine Upgrade for 1975 Corvette
