1968 327/350HP Valves
Old Jun 22, 2016 | 03:40 PM
JimS68's Avatar
JimS68
Default 1968 327/350HP Valves
Following a rebuild of the original engine (previous owner), I heard a loud clicking noise. Took the valve covers off to find severely bent push rods and twisted valve rocker on cylinder 2. A few other rockers were unusually loose so thought it was a poor lashing job and thought I got lucky before a disaster. Relashed and all felt nicely fitted into cam. Valve movement was nice and engine running beautiful. I drove approximately 100 miles before a loud metallic clunk and the same loud clicking. Took valve covers off to find the same problem. Any ideas?Name:  IMG_2187.JPG
Old Jun 22, 2016 | 04:08 PM
MelWff's Avatar
MelWff
are the rocker studs pulling out of the heads? Yours are pressed in.
are there wear marks on the sides of the rocker studs?
Old Jun 22, 2016 | 04:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
Old Jun 22, 2016 | 05:50 PM
JimS68's Avatar
JimS68
I don't see any sign of the studs pulling out of the head. There is a small groove in the cylinder 4 exhaust stud. The rocker from #4 Intake has pushed the rocker on #4 Exhaust onto an angle and the edge of the rocker caused the groove.
Old Jun 22, 2016 | 06:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
Something is either pulling out like the stud or the cams going away causing lash. that valve stem tip is pretty beat up
Old Jun 22, 2016 | 06:40 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Loose Nuts
Were the rocker arm nuts replaced when the heads were rebuilt?
They might be backing out of adjustment. If the studs are all even in height, I would suspect the nuts. When you set the adjustment before were the nuts tight?
I would replace them. It might end up being a cheap easy fix.
Bob K.
Old Jun 22, 2016 | 07:10 PM
JimS68's Avatar
JimS68
Certainly can't hurt to try new nuts although the "crush" ends seemed tight.
Bob K.
Old Jun 23, 2016 | 08:07 AM
augiedoggy's Avatar
augiedoggy
my 74 had the same issue when I bought it with a couple rockers. Someone replaced the arms right before I bought it too which was an indication they knew about the problem.. I have yet to pull the cam since I replaced the motor but I assumed its wiped lobes on the cam from the PO using regular modern ultra low zinc motor oil in it without a zddp additive...
Old Jun 23, 2016 | 10:18 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Studs
Just for added protection, I had my machine shop drill and pin the rocker arm studs. If I remember correctly, it was $3 per stud. I also added roller tipped rockers to both of my L-79 engines. I would either use a dial indicator on the valve train to see if any of the cam lobes are wiped or use a vacuum gauge to determine valve train condition. Good luck. Jerry
Old Jun 23, 2016 | 10:38 PM
azza2u's Avatar
azza2u
Similar thing happened on my 68 327 after I replaced the valve springs. Turned out the one rocker nut was bad and backing off just enough. Coincidentally I'm pretty sure it was the same one you show in your pic. New nut and all has been good since.
Old Jun 23, 2016 | 10:46 PM
7t9l82's Avatar
7t9l82
Pull the rockers and measure the studs.any of the suggestions are valid but press in studs will pull out.
To 1968 327/350HP Valves
