C3 Performance Stealing Accessories in Order
Old Jun 23, 2016 | 04:33 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Default C3 Performance Stealing Accessories in Order
Which C3 engine-driven accessories steal an appreciable amount of HP and in what order?
  • AC
  • Engine-Driven Fan
  • Water Pump
  • Fuel Pump
  • Alternator
  • etc...
Adam
Old Jun 23, 2016 | 04:40 PM
Mark Riles's Avatar
Mark Riles
  • AC
  • Engine-Driven Fan
  • Water Pump
  • Fuel Pump
  • etc...
Adam
Don't forget the alternator. I think I remember reading that all the accessories add up to 30% of the efficiency. The A/C compressor really only adds drag when the clutch is engaged.
Old Jun 23, 2016 | 04:45 PM
NewbVetteGuy
Thanks, Mark. What about the order of most HP sapping potential to least HP sapping potential?
Adam
Old Jun 23, 2016 | 06:09 PM
diehrd's Avatar
diehrd
Fan
Ac
Water
Fuel
Old Jun 23, 2016 | 06:39 PM
BKbroiler's Avatar
BKbroiler
AC - by far, assuming clutch is engaged
fan
water pump
fuel pump
Alternator varies greatly depending on elec demand
Old Jun 23, 2016 | 07:02 PM
Richard454's Avatar
Richard454
But what if you are running an electric AC compressor....
Old Jun 23, 2016 | 07:20 PM
BKbroiler's Avatar
BKbroiler
Didn't know they existed. But in that case the alternator load would be biggest, by far. The added alternator load would have to roughly equal the load of the belt driven compressor.
Old Jun 23, 2016 | 07:21 PM
NewbVetteGuy
Wow... You HAVE to be running an 2nd alternator just for that thing, right?
Can you give me more info on it? I had to try and lookup the website that's on it's sticker but it doesn't seem to exist any more.
Adam
Old Jun 23, 2016 | 07:23 PM
NewbVetteGuy
Jegs sells an electric compressor (looks like a traditional compressor; not like the one in the picture) and it consumes 34amps. Know how to convert from amps into Alternator HP stolen?
Adam
Old Jun 23, 2016 | 07:34 PM
mrvette's Avatar
mrvette
Adam
Well call it 34x say 13.5 volts so volts x amps= Watts, 746 Watts is one HP.....you do the math, too lazy to fetch my calculator....surprised that comp can do the job in a car.....at .6 hp, maybe enough for a beer cooler in back.....
Old Jun 23, 2016 | 07:54 PM
NewbVetteGuy
And that's 0.6 hp worth of electricity; that's assuming a 100% efficient alternator converting 0.6 hp worth of engine HP into 0.6 hp worth of electricity, right? (The actual engine HP consumed would be quite a bit higher.)
Great to see the math! Thanks!
Adam
Old Jun 23, 2016 | 09:53 PM
Richard454's Avatar
Richard454
Adam
It's used for a 18 wheeler cabins. Several states and Canada have "no idle" laws- so this is one of the solutions where they can be in the sleeper w/ AC. Not impressed by the one from Jegs- as the control module doesn't look too weatherproof
Here's the website- http://cool-it.ca/
Also used on electric cars- looked a Prius but it's a 208v piece.
http://www.electriccarpartscompany.c...2kg_p_152.html
Old Jun 24, 2016 | 12:41 AM
lionelhutz's Avatar
lionelhutz
The newer GM EFI systems model the engine output torque so they include the accessory draws. On my car,
The accessory torque (water pump, PS pump, alternator) is modeled as 4ft-lbs to 6ft-lbs going from 1000-6000rpm.
The AC compressor torque is modeled around 10-12 ft-lbs at normal pressures.
The electric compressor will be WAY more efficient because it is optimized to run at one speed. Same applies to electric fans. Both will use NO power when off too compared to engine driven which always use some power.
Old Jun 24, 2016 | 02:05 AM
Haggisbash's Avatar
Haggisbash
The auto trans will be No1 if you have one lol
To C3 Performance Stealing Accessories in Order
